Table of Contents
Antec has just announced the launch of its latest power supply series, the NeoEco Platinum. These 80+ Platinum PSUs achieve a 94% efficiency rating and are fully modular. Pricing starts at $135 for the 650W, $145 for the 750W, and $165 for the 850W. Here is Antec’s press release.
NeoEco PLATINUM: Antec Presents New ATX12V Power Supply Series
24th May 2021 – Antec Inc., leading provider of high-performance computer components and accessories for the gaming, PC upgrade and Do-It-Yourself market, broadens their offer of power supplies with the new line NeoEco Platinum series. The 80 PLUS® PLATINUM rating and the Continuous Power with 650W, 750W and 850W make this modular PSU line an efficient and affordable choice.
The PSU line is now commercially available from USD$ 134.99 for 650W, USD$144.99 for 750W and USD$164.99 for 850W.
The power supplies achieve up to 94 per cent efficiency, so users can reduce their electricity bill significantly. The series features a server-class LLC design with a synchronous rectification based on a DC-DC topology. Japanese capacitors ensure the tightest DC stability and regulation, for reliability that the system can count on. Four PCI Express port connectors enable for multi-GPU support.
The advanced thermal control with the Zero RPM mode enables to turn the fan off at low loads to provide absolute silence. With the 120 mm silent fan, the NeoEco Platinum can optimize the balance between cooling and noise. This PSU line is engineered according to the newest PSU guidelines and is compatible with the latest generation of CPUs. The fully modular, flat DC cables make builds and upgrades easy, with great-looking results.
A 7-year Antec Quality warranty, a whisper-quiet 120 mm fan controlled by Antec’s Thermal Manager and CircuitShield™ Industrial Grade protection make NeoEco Platinum one of the best choices available.
Product Features:
- Top-grade Japanese capacitors for clean DC-DC performance
- 80 PLUS® Platinum certified – up to 94% efficiency, to reduce your electricity bill
- 7-year warranty
- 100% Modular cable management –Improves airflow and reduces clutter
- Zero RPM mode, which uses thermal sensors to activate the fan only when you need it
- 4x PCI-E connectors for multiple GPU support
- Delivers non-stop industrial class performance for high-end computer systems at up to 45°C ambient
For more information, please follow us on Facebook and visit our website at https://www.antec.com/product/power-series#platinum
Recent News
Loading new replies...
