Antec just announced several high-end power supplies that will hit the shelves in early May. The Signature Series Platinum and Titanium PSUs are rated for a minimum of 1000w and sport generous 10-year warranties.
Full details from Antec below:
Antec, a leading provider of high-performance computer components and accessories for the gaming, PC upgrade and Do-It-Yourself market, broadens its range of power supplies with the new Signature Series Platinum and Titanium models. The PSU line MSRP is now commercially available from US$ 229.99 for the 1000W Platinum and US$ 269.99 for the 1300W Platinum and US$ 279.99 for the 1000W Titanium PSU. All models will be available at the beginning of May in US.
Equipped with features that ensure peak performance for the enthusiast and gaming-oriented segment, the Signature Series features a fully-modular cable management system which enables users to use only the cables which are needed, greatly simplifying installation and helps clear out excess cables that can obstruct and reduce airflow. The whisper-quiet, fluid dynamic bearing 135mm fan provides high airflow with durability and longevity. The Zero RPM fan mode further ensures a longer-lasting and quieter system, by using thermal sensors to activate the fan only when you need it.
All models of the Signature Series are a great choice for a reliable and efficient PC system for gamers and professionals. This new PSU line from Antec pushes the standard for excellence with the circuit shield suite of industrial protections and is backed by a 10-year warranty. Their PhaseWave Design offers a server-class full-bridge LLC design with a synchronous rectification based on a DC-DC topology. The power supplies are engineered according to the newest PSU guideline ATX12V 2.4 and are hence compatible with the latest generation of CPUs.
Product Features:
- 100% top-grade Japanese capacitors for clean DC-DC performance
- 80 PLUS® Titanium / Platinum certified to reduce your electricity bill
- 10-year warranty and lifetime global support
- 100% Modular cable management – Improves airflow and reduces clutter
- CircuitShield – Full suite of industrial grade protections: OCP, OVP, UVP, SCP, OPP, OTP, SIP, NLO
- Zero RPM mode, which uses thermal sensors to activate the fan only when you need it
- 28(18+10) pin MBU socket – For possible future MBU connectors
- 99%+12V – Output for maximum CPU & GPU support
- OC Link – Allows 2 Signature PSUs to work in tandem to power the most demanding systems.
- Delivers non-stop industrial class performance for high-end computer systems at up to 40°C ambient
For more information please visit https://antec.com/product/power-series.php#signature and follow us on our Social Media Channels.
Stay safe and indoors!
No replies yet
Loading new replies...
