ASRock Phantom Gaming Z890I NOVA WiFi Motherboard Review
We usually focus on ATX format motherboards, but many users love small form factor computers and ITX motherboards. For those users, we have the ASRock Z890I NOVA motherboard, which promises excellent performance and high-end features in a tiny space. The Z890I NOVA supports all the latest technologies, including the Intel Core Ultra processors and the fastest DDR5 CUDIMM memory, but it’s not everything. You have to read our review to find out what else it offers. Let’s begin with a long list of specifications and features, and I will describe the most important ones.
FAST
MYSTERIOUS
UNBEATABLE
Phantom Gaming is designed by gamers and for gamers! Underneath its relentless appearance lie plentiful gaming oriented features and excellent gaming capabilities. It’s all about bringing a new gaming experience to gamers!
Nova is the most significant energy discharge ever witnessed by mankind, it’s super-powerful which represents the performance our motherboard can deliver.
Specifications and Features of the ASRock Z890I NOVA
The Z890I Nova is the only ASRock ITX motherboard for the new Intel processor series and one of only a few motherboards in this size available on the market. A minimal choice doesn’t mean nothing is interesting as ASRock made sure that this one motherboard covers all gamers’ needs. The long list of key features suggests what we can expect.
ASRock Z890I NOVA; Source: ASRock
Key Features
  • Supports Intel® Core™ Ultra Processors (Series 2) (LGA1851)
  • 12+1+1+1+1 Power Phase, 110A SPS for VCore
  • 2 x DDR5 DIMMs
    Supports Dual Channel, up to 9866+ (OC)
  • 1 PCIe 5.0 x16
  • Graphics Output Options: 1 HDMI, 2 Thunderbolt™ 4 Type-C
  • Realtek ALC4082 7.1 CH HD Audio Codec, Nahimic Audio
  • 2 SATA3
    1 Blazing M.2 (PCIe Gen5 x4)
    1 Hyper M.2 (PCIe Gen4 x4)
    1 Hyper M.2 (PCIe Gen4 x4 & SATA3)
  • 2 Thunderbolt™ 4 Type-C (Rear)
    1 USB 3.2 Gen2x2 Type-C (Front)
    6 USB 3.2 Gen2 Type-A (Rear)
    2 USB 3.2 Gen1 (Front)
    2 USB 2.0 (Front)
  • 5Gbps LAN
  • 802.11be Wi-Fi 7 + Bluetooth
  • Supports BIOS Flashback, Memory OC Shield, 20K Caps with 1000uF Capacitance
Intel Z890 Chipset Specifications
Intel Z890 Chipset
Intel® Core™ Ultra desktop processors (Series 2) are the foundation of the AI PC, and Intel® Z890 chipsets are designed to enable their intelligent performance and next-gen connectivity. For everything from elite gaming rigs to enthusiast creator PCs, the Intel® Z890 chipset maximizes the peripheral and connectivity experience.
Intel Z890 Chipset – Source: Intel
The Z890 is the flagship Intel chipset for the new desktop processors so that we can expect the best device support and features. Below, you can see the simplified chipset diagram with marked new features. We have more PCIe lanes and M.2 SSD PCIe lanes in general, an integrated sensor hub, higher DDR5 support – up to 6400MT/s and CUDIMM support (overclocking frequencies are much higher), better support for AI technologies and two Thunderbolt 4 ports, which were available on earlier motherboards, but as an additional option.
Z890 Chipset Diagram – Source: Intel
ASRock Z890I NOVA Specifications
CPU Support– Supports Intel® Core™ Ultra Processors (Series 2) (LGA1851RL-ILM)
– Supports Intel® Hybrid Technology
– Supports Intel® Turbo Boost Max 3.0 Technology
– Supports Intel® Thermal Velocity Boost (TVB)
– Supports Intel® Adaptive Boost Technology (ABT)
– Integrated NPU for dedicated AI acceleration
Chipset– Intel® Z890
Memory– Dual Channel DDR5 Memory Technology
– 2 x DDR5 DIMM Slots
– Supports DDR5 non-ECC, un-buffered memory up to 9866+(OC)*
– Supports Clocked Unbuffered DIMM (CUDIMM)
– Max. capacity of system memory: 128GB*
– Supports Intel® Extreme Memory Profile (XMP) 3.0x
*1DPC 1R Up to 9866+ MHz (OC), 6400 MHz Natively.
1DPC 2R Up to 6800+ MHz (OC), 6400 MHz Natively.
Onboard Graphics
– Intel® Xe LPG Graphics Architecture
– 1 x HDMI 2.1 TMDS/FRL 8G Compatible, supports HDR, HDCP 2.3 and max. resolution up to 4K 120Hz
– 2 x Intel® Thunderbolt™ 4, support HDCP 2.3 and max. resolution up to 8K 60Hz / 5K 120Hz*
* Intel® UHD Graphics Built-in Visuals and the VGA outputs can be supported only with processors which are GPU integrated.
Supports two 4K displays or one 8K display
Only the CPU’s embedded graphics can be displayed through Thunderbolt™ ports.
If you want to display to a Thunderbolt™ monitor, please use CPU models with embedded graphics.
Audio– 7.1 CH HD Audio with Content Protection (Realtek ALC4082 Audio Codec)
– Nahimic Audio
LAN
– 5 Gigabit LAN 10/100/1000/2500/5000 Mb/s
– Realtek RTL8126
Wireless Communications Module– 802.11be 2×2 Wi-Fi 7 Module
– Supports IEEE 802.11a/b/g/n/ac/ax/axe/be
– Supports 2.4GHz/5GHz/6GHz* frequency band
– Supports 320MHz channel bandwidth with 6GHz* frequency band
– 1 antenna to support 2 (Transmit) x 2 (Receive) diversity technology
– Supports Bluetooth 5.4
– Supports MU-MIMO
* Wi-Fi 7 (6GHz band) will be supported by Microsoft Windows® 11. The availability will depend on the different regulation status of each country and region. It will be activated (for supported countries) through Windows® Update and software updates once available.
Expansion Slots
CPU:
– 1 x PCIe 5.0 x16 Slot (PCIE1), supports x16 mode*
Chipset:
– 1 x Vertical M.2 Socket (Key E), supports type 2230 WiFi/BT PCIe WiFi module
– 15μ Gold Contact in VGA PCIe Slot (PCIE1)
* PCIE1 supports PCIe riser cards to extend one x16 slot to x8/x8 or x8/x4/x4 slots.
Supports NVMe SSD as boot disks
Storage Interface
CPU:
– 1 x Blazing M.2 Socket (M2_1, Key M), supports type 2280 PCIe Gen5x4 (128 Gb/s) mode*
– 1 x Hyper M.2 Socket (M2_2, Key M), supports type 2280 PCIe Gen4x4 (64 Gb/s) mode*
Chipset:
– 1 x Hyper M.2 Socket (M2_3, Key M), supports type 2280 SATA3 6.0 Gb/s & PCIe Gen4x4 (64 Gb/s) modes*
– 2 x SATA3 6.0 Gb/s Connectors
* Supports Intel® Volume Management Device (VMD)
– Supports RAID 0 and RAID 1 for SATA storage devices
– Supports RAID 0, RAID 1, RAID 5 and RAID 10 for M.2 NVMe storage devices
* Requires additional M.2 NVMe expansion cards to support RAID 10
USBCPU:
– 2 x Thunderbolt™ 4 Type-C (Rear) Chipset:
– 1 x USB 3.2 Gen2x2 Type-C (Front)
– 6 x USB 3.2 Gen2 Type-A (Rear)
– 2 x USB 3.2 Gen1 (Front)
– 2 x USB 2.0 (Front)
* All USB ports support ESD Protection
Internal I/O Connectors– 1 x Thermistor Cable Header
– 2 x Addressable LED Headers*
– 1 x CPU Fan Connector (4-pin) (Smart Fan Speed Control)**
– 1 x Chassis Fan Connector (4-pin) (Smart Fan Speed Control)**
– 1 x AIO Pump Fan Connector (4-pin) (Smart Fan Speed Control)***
– 1 x 24 pin ATX Power Connector (Hi-Density Power Connector)
– 1 x 8 pin 12V Power Connector (Hi-Density Power Connector)
– 1 x Front Panel Audio Connector (15μ Gold Audio Connector)
– 1 x USB 2.0 Headers (Supports 2 USB 2.0 ports)
– 1 x USB 3.2 Gen1 Headers (Supports 2 USB 3.2 Gen1 ports)
– 1 x Front Panel Type C USB 3.2 Gen2x2 Header (20 Gb/s)
* Support in total up to 5V/3A, 15W LED Strip
** CPU_FAN and CHA_FAN1 support the fan power up to 2A (24W).
*** AIO_PUMP supports the fan power up to 3A (36W).
AIO_PUMP can auto detect if 3-pin or 4-pin fan is in use.
Back Panel Connectors
– 2 x Antenna Ports
– 1 x HDMI Port
– 2 x Thunderbolt™ 4 Type-C Ports (40 Gb/s for USB4 protocol; 40Gb/s for Thunderbolt™ protocol)*
– 1 x Optical SPDIF Out Port
– 6 x USB 3.2 Gen2 Type-A Port (10 Gb/s)
– 1 x RJ-45 LAN Port
– 1 x BIOS Flashback Button
– 1 x Line Out Jack (Gold Audio Jack)
– 1 x Microphone Input Jack (Gold Audio Jack)
* Supports USB PD 3.0 up to 5V@3A (15W) charging
W) charging
Unique Features
Superb Productivity
– PCIe Gen5 (Graphics, M.2)
– Dual Channel DDR5
– Thunderbolt™ 4 Type-C Ports (40 Gb/s)
Rock-Solid Durability
– Server-Grade Low-Loss PCB
– 12+1+1+1+1 Power Phase, 110A SPS for VCore with Enlarged Heatsink Armor
– Memory OC Shield
– Flexible Integrated I/O Shield
– 20K Long-lasting Black Caps (high quality and conductive polymer capacitors) Ultrafast Gaming
– 5G LAN, 802.11be Wi-Fi 7 Module
EZ Update
– BIOS Flashback Button
– ASRock Auto Driver Installer
EZ Troubleshooter
ASRock Post Status Checker
Software and UEFI
Software
– ASRock Motherboard Utility (Phantom Gaming Tuning)
– ASRock Phantom Gaming LAN Software
– ASRock Polychrome SYNC*
UEFI
– ASRock EZ Mode
– ASRock Full HD UEFI
– ASRock My Favorites in UEFI
– ASRock Instant Flash
*These utilities can be downloaded from ASRock Live Update & APP Shop.
OS Support– Microsoft Windows® 11 64-bit
Accessories
– 2 x SATA Data Cables
– 1 x ASRock WiFi 2.4/5/6 GHz Antenna
– 1 x ARGB Splitter Cable
– 3 x Screws for M.2 Sockets
Form Factor– Mini-ITX Form Factor: 6.7-in x 6.7-in, 17.0 cm x 17.0 cm
– 10 Layer PCB
– 2oz Copper PCB
Even though the Z890I NOVA is in ITX format, the specifications should satisfy most users, even those who are more demanding. The motherboard provides a robust power section with a 12+1+1 VRM design and the best components on desktop motherboards. It also gives us three fast M.2 sockets and the latest Realtek ALC4082 audio codec. Barely any ITX motherboard has three M.2 sockets, and most new motherboards use older ALC1220 series audio codecs, so even these two features give an advantage to the little ASRock motherboard. The list of advantages is longer.
ASRock Z890I NOVA Features and Specifications; Source: ASRock
The motherboard supports all desktop Core Ultra processors and DDR5 RAM up to 9866MT/s+. Anything above 8600MT/s will use the clock driver, so in other words, it will be CUDIMM. We could run quick tests at 9866MT/s, but our test components showed instability. On the other hand, 9733MT/s was fully stable, and the motherboard with the tested official BIOS has a RAM OC profile at 9733MT/s, which works perfectly stable. The motherboard acts like it could handle over 10000MT/s, but finding a strong enough processor won’t be easy.
The power design is strong enough to handle every desktop CPU at much higher voltages than standard. However, this is an extreme overclocking scenario that only a few users will consider. On the other hand, we couldn’t hear any coil whine or other noises under high load from the motherboard itself. All voltages were perfectly stable, and the CPU was overclocking as high as on ASRock ATX motherboards.
The Z890I NOVA offers three M.2 sockets. One, called Blazing, works up to PCIe 5.0 x4 mode (connected to the CPU), and two (on the back of the PCB) work up to PCIe 4.0 x4. M.2 sockets don’t share the bandwidth with the first PCIe x16 slot and are no other limitations. RAID modes are also supported, but RAID 10 works only with a PCIe NVMe card, so it can’t be used with a discrete graphics card unless we use riser/splitter cards. Bifurcation is available as a BIOS setting.
The new Intel series doesn’t have native USB4 controllers compared to new AMD motherboards. However, all Z890 motherboards have Thunderbolt 4, which supports USB4 devices. Thunderbolt 4 is a better option for some users, as it provides more functionality. Most users won’t see a difference.
Like all high-end motherboards, the NOVA has a BIOS flashback button on the back I/O. I only miss the clear CMOS button, which is handy while overclocking.
Optimized VRM Design
Exclusive 20K Cap with 1000uF Capacitance
The upgraded 20K Black capacitor not only extends the lifespan to 20,000 hours but also increases the capacitance value from 560uF to 1000uF, bringing several benefits:
●Higher Capacitance: Greater charge storage for better support under high loads.
●Lower Ripple: Reduced power output fluctuations, improving quality.
●More Stable Output Current: Stable power supply, minimizing voltage impacts.
●Better Performance & System Stability: Increased reliability and consistent performance.
12+1+1+1+1 Power Phase Design
Featuring sturdy components and completely smooth power delivery to the CPU. Plus, it offers unmatched overclocking capabilities and enhanced performance with the lowest temperature for advanced gamers as well.
SPS (Smart Power Stage)
Dr.MOS design features the latest SPS (Smart Power Stage) technology. It’s optimized for monitoring current and temperature of each phase, thus delivering smoother and neater power to the CPU with enhanced performance and OC capability.
CPU overclocking requires higher current, ASRock Hi-Density Power connectors is able to withstand current higher traditional CPU 8-pin and ATX 24-pin connector, giving a more stable system as well as lowering the risk of fire under heavy overclocking.
Premium PCB Solution
2-ounce copper inner layers that provide stable signal traces and power shapes! Delivering lower temperature and higher energy efficiency for overclocking.
The 10 Layer PCB provides stable signal traces and power shapes delivering lower temperature and higher energy efficiency, ensures a reliable and long-lasting system while delivering ultimate performance without any compromise.
DDR5 XMP & EXPO Support
Derived from the “built for stable and reliable” designing concept, ASRock does not compromise on any details. This motherboards is built with high quality materials, enthusiasts are able to enjoy the boost of DDR5 memory overclocking performance by enabling the pre-tested profiles. Make sure the memory modules are Intel® XMP/AMD EXPO™ capable and overclocking can be made so affordable, satisfying and absolutely no sweat at all.
* There are certain risks involved with memory overclocking and may affect your system’s stability. Please realize that overclocking should be done at your own risk and expense. EXPO/XMP profile support may vary by different system configuration, memory modules and motherboard models. Please refer to Memory QVL for the completed support list.
ASRock’s exclusive Memory OC Shield is a patented feature engineered to reduce electromagnetic interference (EMI) that could affect memory overclocking. By shielding memory modules from EMI noise and optimizing the layout, the Memory OC Shield enhances stability and reliability during high-frequency operations, enabling users to push their systems to the maximum potential.
High Speed M.2 Solution
PCIe Gen5 Blazing M.2
The Blazing M.2 accommodates the latest PCI Express 5.0 standard, performing twice the bandwidth compared to the previous generation. With a breathtaking 128Gb/s transfer speed, it is ready to unleash the full potential of future ultrafast SSDs.
Enlarged M.2 HeatsinkThe extra large aluminum alloy M.2 heatsink effectively improves heat dissipation to keep those high-speed M.2 SSDs as cool as possible. It can provide better stability while maintaining top performance.
Tired of dropping screws or screws missing inside the chassis? The enhanced M.2 heatsink with an anti-drop screw design makes the sure installation process more easily.
Intelligent Cooling Design
PWM/DC Fan Support
ASRock fan headers automatically detect whether fans are running in DC or PWM mode, allowing users to fine-tune the fan curve and achieve quieter operation.
CPU Fan Connector
Chassis Fan Connectors
Thermistor Header
The thermistor cable and thermistor header provide an additional source for temperature monitoring, offering customized thermal management solutions based on workload. Thermal management settings can be easily configured via Fan-Tastic Tuning or UEFI.
Fan-Tastic Tuning
ASRock A-Tuning Fan-Tastic Tuning function enables users to auto-detect the minimum duty of each fan with a single click. Users can also easily adjust the fan curve via the visualized UI interface, meeting their system’s cooling performance and noise reduction requirements.
Composite VRM Heatsink
It is equipped with a composite VRM heatsink combining a cooling fan, bigger aluminum sink and heat pipe for maximum heat dissipation.
Wi-Fi 7
Wi-Fi 7 offers higher data throughput, lower latency, and Multi-link Operation. These features ensure a smooth and real-time interactive experience, making the VR/AR experience more immersive and connected.
Latest WiFi 7 technology delivers extreme wireless internet speeds and low latency, with higher throughput and Multi-RU as well as puncturing technology. The new WiFi 7(802.11be) technology is able to accelerate cloud-based gaming, 8K video streaming, and video conferencing.
Multi-link Operation (MLO) enables the simultaneous use of multiple bands and channels, boosting speed and throughput while reducing latency for a smoother, faster internet experience.
The new Wi-Fi antenna design is ideal for high-bandwidth, low-latency applications and ensures a stable connection.
Thunderbolt™ 4 technology brings speed and versatility to the most advanced USB Type-C, offering a fast and simple level of connection for work or home. It enables lightning-fast data transfer up to 40Gbps and connects external monitors, Thunderbolt™, and USB devices with a single Thunderbolt 4 cable.
Please refer to Intel®What is Thunderbolt 4” page for more detail.
Optimized 5 Gb/s LAN
ASRock’s 5Gb/s LAN Connector features an exclusive, patent-pending design, boasting superior electromagnetic interference resistance, ensuring high-speed stable performance and providing users with a better networking experience.
Front Panel USB 3.2 Gen2x2 Type-C Header
The latest USB 3.2 Gen2x2 Type-C delivers up to 20 Gbps data transfer rate which is 2x as fast as previous generation, providing a blazing fast data transfer interface with reversible USB Type-C design that fits the connector either way.
High Definition Sound Effects
Nahimic Audio
Whether you are using headphones, a headset, external or internal speakers, via USB, Wi-Fi, analog output or even HDMI, Nahimic Audio offers you the most engaging listening experience, vibrant and rich with details.
Enhance Communication Quality
The Powerful algorithms to ensure the best noise-free conversation, giving a constant vocal level no matter the distance from your mic. The Nahimic audio engine dynamically clear the sound and remove interference noise and lower the voice variation. Result is a better comprehension and less fatigue.
●Static Noise Suppression
●Echo Cancellation
●Lateral Sound Cancellation
●Voice Stabilizer
Ultimate Gaming Experience
●Sound Tracker
The Sound Tracker is a visual indicator that points out the directions from which predominant sounds are coming. Each sound is properly positioned in 360° on a radar for a full immersion during the game.
●Works on any devices!
Enjoy the vibrant and high-quality Surround Sound on all your favorite audio devices: Jack, USB, Bluetooth, HDMI, S/PDIF. Nahimic is compatible with all of your favorite audio tools and ensures the best sound with any of them. Nahimic measure and improve to optimize our technology and offer you the best experience.
POLYCHROME RGB
This motherboard features onboard RGB headers and addressable RGB headers that allow motherboard to be connected to compatible LED devices such as strip, CPU fans, coolers, chassis and so on. Users may also synchronize RGB LED devices across the Polychrome RGB Sync-certified accessories to create their own unique lighting effects.
*The addressable RGB LED header supports WS2812B addressable RGB LED strip (5V/Data/GND), with a maximum power rating of 3A (5V), a max of 80 LEDs and length within 2 meters.
*The RGB LED header supports standard 5050 RGB LED strip (12V/G/R/B), with a maximum power rating of 3A (12V) and length within 2 meters.
Deluxe Accessories
The ARGB Splitter Cable enables easy management of multiple ARGB devices through a single controller. With its splitting capability, it streamlines your lighting setup for a unified and dynamic aesthetic.
The thermistor cable and thermistor header provide an additional source for temperature monitoring, offering customized thermal management solutions.
EZ Setting
No need to worry about lack of disk drive! Asrock preinstall LAN driver to ensure that you are able to install all drivers needed in an easier way than using SCD.
step1 : Install Auto Driver Installerstep2 : Update drivers neededstep3 : Done!
BIOS Flashback
Get the most convenient BIOS flashing with just a simple click. Users can easily achieve the latest BIOS support with a USB and power supply, No CPU, RAM or other components required.
Unlike most so called pre-mounted I/O shield that is only decorated with fancy color schemes. We reserve more tolerance space and allow IO shield is adjustable when installing, thus fitting chassis perfectly without any mechanical issue.
The list of Key Features is also available on ASRock’s website.
The NOVA ITX doesn’t have all the easy installation features. Easy graphics card removal would be amazing, but the PCB is not large enough for the mechanism used on ATX motherboards. Also, easy-to-remove M.2 heatsinks are significantly larger, where the ITX form factor doesn’t give us enough space. Most users won’t find it a disadvantage, but it would be an excellent addition to already pretty good design.
Retail Packaging and Accessories
The motherboard arrived in a retail package. The box is relatively small, but that’s expected, as the motherboard is also tiny. The package design and contents are the same as those in stores.
Inside the box is everything we need for the installation, including a WiFi antenna, SATA data cables, thermal sensor cable, M.2 screws, keyboard key cap, ASRock logo badge/sticker, RGB extension/splitter cable, and a quick user’s guide (an extended version of the manual is available on the website). M.2 screws could be replaced by something easy to install as they’re tiny and easy to drop. The M.2 heatsink on the top has anti-drop screws, but we won’t find it on the back of the PCB.
A Closer Look at the ASRock Z890I NOVA
The Z890I NOVA shares the design with ATX models, and I like it more than the last-generation ASRock ITX motherboards. Everything looks clean, and even though the motherboard is well-equipped, it feels like there was no challenge in installing everything in such a small space.
ASRock used large heatsinks without interfering with possible cooling options or other devices. Installing a large AIO cooler with an LCD shouldn’t be a problem. Everything is easy to access, but installing the motherboard in a small ITX case can be tight.
There is also a new feature called “MEMORY OC SHIELD.” It can be seen between a CPU socket and RAM slots, which promises better RAM overclocking and stability. Considering the very high RAM support, it seems like it works well.
The motherboard fits every ITX-size PC case. However, if we use higher-wattage processors, we must pick a case with enough space for a proper cooler. Core Ultra 7 and 9 processors are rated at up to 250W TDP, so they require larger tower coolers or AIO coolers with at least 240mm radiators for optimal work.
The motherboard has three fan headers, which can be controlled in the BIOS or ASRock software. The CPU and chassis fan headers are rated 2A/24W, while the AIO cooler header can handle 3A/36W. It’s enough for a quite large cooling setup with multiple fans connected via splitters.
The NOVA uses large heatsinks and high-performance thermal pads. Even then, ASRock decided to use a fan under the largest VRM heatsink to lower the temperatures. The fan is very quiet, so I didn’t even notice it was there at first, but I found it after removing the heatsinks.
The motherboard also has an aluminum backplate with thick thermal pads on the back of the VRM area. Although unnecessary, the backplate affects the temperatures under load and may improve overclocking results during extended high load.
The PCIe 5.0 M.2 heatsink has a thermal pad, while two M.2 sockets on the back are left without additional cooling. The backside M.2 sockets are designed for PCIe 4.0 SSDs, and even though they support all the PCIe SSDs, the optimal would be to use the DRAM-less series as they keep much lower temperatures.
The Z890 chipset has a single-die design and doesn’t generate much heat, so a small heatsink can efficiently cool it. The NOVA’s chipset heatsink is connected to the M.2 heatsink, and nothing is overheating with the installed PCIe 5.0 M.2 SSD, which confirms it doesn’t require any exceptional cooling for complete stability.
Below are additional close-ups of the ICs on the motherboard. There are no surprises, except for the audio area and the 5Gbps Realtek LAN used. Nearly everything is much stronger than that specified by Intel for the new generation of motherboards. In particular, connectivity options are better as we get 5GbE NIC and WiFi 7 instead of 1/2.5GbE NIC and WiFi 6/6E, which is standard for the Z890.
UEFI BIOS and Software
BIOS/UEFI
The new motherboard series BIOS/UEFI is similar to the last generation, and it’s still user-friendly. The Z890 BIOS is kept in colors to match the motherboard design. The motherboard arrived with the latest BIOS version on the day of shipping, but before we started tests, there were already newer releases, including the 2.14 OC01 BIOS, which we used for the review.
The BIOS has two modes: an easy mode for all those who are fine with basic settings and an advanced mode for those who like to adjust everything or need specific settings for their work.
Easy Mode
ASRock Z890I NOVA - BIOS/UEFI
ASRock Z890I NOVA – BIOS/UEFI
Advanced Mode
Advanced Mode – OC Tweaker
Advanced Mode – Advanced
Advanced Mode – Tool
Advanced Mode – H/W Monitor
Advanced Mode – Security
Advanced Mode – Boot
Advanced Mode – Exit
ASRock Software
ASRock adds its software, which includes RGB adjustment, fan control, overclocking and diagnostic options, and software/firmware updates. We wish to see it as one application, but sadly, it’s only available for three separate applications.
The RGB worked with the most popular RAM brands, like G.Skill and Kingston. Less popular, like KLEVV or V-Color, also worked fine.
Fan control works without issues and can be easily managed by the software.
Most overclocking options, like the CPU ratio, won’t require a PC’s restart, which is rare in other motherboard brands.
Test Setup and Performance of the ASRock Z890I NOVA
Test System Components
MotherboardsASRock Z890I NOVA / Core Ultra 7 265K
ASRock Z890 Taichi OCF / Core Ultra 7 265K
ASRock X870E Taichi / Ryzen 7950X
ASRock X870 Riptide / Ryzen 7950X
Biostar X870E Valkyrie / Ryzen 7950X
Gigabyte Z890 AORUS Master / Core Ultra 7 265K
Gigabyte X870E AORUS Pro ICE / Ryzen 7950X
Gigabyte B650E AORUS Master / Ryzen 7950X
ASUS Crosshair X670E Gene / Ryzen 7950X
Gigabyte X570 Ultra / Ryzen 5900X
MSI Z790 Ace MAX / 14900K
CPUsAMD Ryzen 9 7950X
AMD Ryzen 9 5900X
Intel Core Ultra 7 265K
Intel Core i9 14900K
CPU CoolerCustom liquid cooling
MemoryDDR5: Kingston Renegade RGB 2x48GB@DDR5-6400 CL32 (auto sub-timings) / Hynix M-die
DDR4: Acer Predator 2x8GB DDR4-3600 CL14@XMP / Samsung B-die
SSDAcer Predator GM7000 2TB NVMe SSD (OS + Applications), Crucial T705 2TB NVMe SSD for CrystalDiskMark
Power SupplyFSP  Hydro PTM Pro 1200W 80+ Platinum PSU
Video CardColorful RTX4080 Advanced OC 16GB
Operating SystemWindows 11 Pro x64
CPU and Memory Performance
AIDA64 Cache and Memory Benchmark – Raw Data
Motherboard / CPUReadWriteCopyLatency
ASRock Z890I NOVA / CU7 265K99904940889879581,2
ASRock Z890 Taichi OCF / CU7 265K101054945569916480,1
AORUS Z890 Master / CU7 265K100031941129806082,5
ASRock X870E Taichi / R9 7950X82461868797624272,4
ASRock X870 Riptide / R9 7950X81124860457587974,9
Biostar X870E Valkyrie / R9 7950X79984848727388476,4
AORUS X870E PRO ICE / R9 7950X87846941248183462,1
AORUS B650E Master / R9 7950X88054939488070860,1
CROSSHAIR X670E GENE / R9 7950X88328924868092464,2
AORUS X570 Ultra / R9 5900X54136532594880560,2
MSI Z790 Ace MAX / i9 14900K10137310035710142765,2
ASRock Z890I NOVA - AIDA64 Memory Tests
ASRock Z890I NOVA – AIDA64 Memory Tests
Synthetic memory tests show high performance compared to other Z890 motherboards. The only weak point of the new Intel series is memory latency, which is about 15ns worse than we wish.
For comparison purposes, all the results were made on the 6400MT/s memory kit, so we can count on much better bandwidth if we use high-frequency CUDIMM. The motherboard supports all available CUDIMM memory kits, up to 9600MT/s. RAM scales well on the new Intel generation up to at least 8800-9000MT/s, which is the limit for Gear 2 on most popular motherboards. On ASRock motherboards like Z890I NOVA or Z890 OCF, we could reach even 9200MT/s Gear 2.
AIDA64 CPU Benchmark – Raw Data
Motherboard / CPUPhotoZlibAESSHA3
ASRock Z890I NOVA / CU7 265K654971987,42182209058
ASRock Z890 Taichi OCF / CU7 265K655241990,12181589062
AORUS Z890 Master / CU7 265K654361980,22181669050
ASRock X870E Taichi / R9 7950X529712485,638624811246
ASRock X870 Riptide / R9 7950X532442474,638344811245
Biostar X870E Valkyrie / R9 7950X527892452,838187711098
AORUS X870E PRO ICE / R9 7950X539742476,738587011214
AORUS B650E Master / R9 7950X542472458,538437311136
CROSSHAIR X670E GENE / R9 7950X532422471,238347910805
AORUS X570 Ultra / R9 5900X208221342,92104635296
MSI Z790 Ace MAX / i9 14900K656612344,82867398265
ASRock Z890I NOVA - AIDA64 CPU Benchmarks
ASRock Z890I NOVA – AIDA64 CPU Benchmarks
AIDA64 CPU tests show that the Z890I NOVA performs slightly worse than the Z890 OCF and marginally better than the AORUS Z890 Master. The difference isn’t significant, but it confirms the motherboard works well and the CPU boosts up to expected frequencies.
AIDA64 FPU Benchmark – Raw Data
Motherboard / CPUJuliaMandelSinJuliaFP64 RT
ASRock Z890I NOVA / CU7 265K178888841021278915724
ASRock Z890 Taichi OCF / CU7 265K178912840741284715824
AORUS Z890 Master / CU7 265K178901840191274215782
ASRock X870E Taichi / R9 7950X2587241384873375834278
ASRock X870 Riptide / R9 7950X2568461391123368834316
Biostar X870E Valkyrie / R9 7950X2571121371843351234088
AORUS X870E PRO ICE / R9 7950X2578691376393368934059
AORUS B650E Master / R9 7950X2630301398733364334141
CROSSHAIR X670E GENE / R9 7950X2560271301703325733775
AORUS X570 Ultra / R9 5900X155039851571956612843
MSI Z790 Ace MAX / i9 14900K168473841241949318234
ASRock Z890I NOVA - AIDA64 FPU Benchmarks
ASRock Z890I NOVA – AIDA64 FPU Benchmarks
AIDA64 FPU tests suggest that all Z890 motherboards perform similarly. The Taichi again looks slightly better, but it’s not significant.
Cinebench R23, POVRay, 7Zip – Raw Data
Motherboard / CPUR23 (S)R23 (M)POV-Ray7Zip
ASRock Z890I NOVA / CU7 265K217735772276912155,88
ASRock Z890 Taichi OCF / CU7 265K217435768276842158,224
AORUS Z890 Master / CU7 265K217535758276523156,752
ASRock X870E Taichi / R9 7950X201638852282146216,48
ASRock X870 Riptide / R9 7950X198938684274164214,45
Biostar X870E Valkyrie / R9 7950X194838142271879212,12
AORUS X870E PRO ICE / R9 7950X201338360285767216,18
AORUS B650E Master / R9 7950X200438384267130202,382
CROSSHAIR X670E GENE / R9 7950X200238340279272219,22
AORUS X570 Ultra / R9 5900X159820983288281117,115
MSI Z790 Ace MAX / i9 14900K217936600228088213,144
ASRock Z890I NOVA - Cinebench R23, POV-Ray, 7-Zip
ASRock Z890I NOVA – Cinebench R23, POV-Ray, 7-Zip
The results of additional tests show differences at the edge of the error margin. At the same time, the performance is as high as expected.
PCMark 10 Applications – Raw Data
Motherboard / CPUWordExcelPowerPointEdge
ASRock Z890I NOVA / CU7 265K8520365981592815938
ASRock Z890 Taichi OCF / CU7 265K8516365681598715918
AORUS Z890 Master / CU7 265K8460364271584615942
ASRock X870E Taichi / R9 7950X11046378161742216312
ASRock X870 Riptide / R9 7950X10848372891740416112
Biostar X870E Valkyrie / R9 7950X10546373841718916080
AORUS X870E PRO ICE / R9 7950X11011378191741516234
AORUS B650E Master / R9 7950X10924376941739816197
CROSSHAIR X670E GENE / R9 7950X10914377121740216194
AORUS X570 Ultra / R9 5900X11180316851790812932
MSI Z790 Ace MAX / i9 14900K9618380171841216357
ASRock Z890I NOVA - PCMark 10 Applications
ASRock Z890I NOVA – PCMark 10 Applications
In the PCMark 10 Applications benchmark, the Z890I NOVA performs great and is, again, very close to other Z890 motherboard results and even slightly better.
Gaming Performance
Gaming benchmarks show about the same results on all Z890 motherboards. Differences are close to the margin of error, so the user’s experience will be similar in all cases. The tests show that the Z890I NOVA motherboard performs well; the main difference in our comparison is the used processor.
ASRock Z890I NOVA - 3DMark Fire Strike Extreme
ASRock Z890I NOVA – 3DMark Fire Strike Extreme
ASRock Z890I NOVA - 3DMark Time Spy
ASRock Z890I NOVA – 3DMark Time Spy
ASRock Z890I NOVA - Games at 1440p
ASRock Z890I NOVA – Games at 1440p
Used processors greatly affect popular games. The Core Ultra series isn’t the fastest option, but the results are still pretty good. Once again, all the Z890 motherboards have similar results.
Storage Performance
M.2 SSD
ASRock Z890I NOVA - M.2 SSD performance
ASRock Z890I NOVA – M.2 SSD performance
The M.2 performance has been tested using the Crucial T705 2TB NVMe PCIe 5.0 x4 SSD. The maximum bandwidth is around 12.5GB/s, which is typical for Intel chipsets. On the other hand, low queue random operations are up to 20% faster than we can see on motherboards with AMD chipsets. Overall, the M.2 performance is as high as expected.
USB
ASRock Z890I NOVA - USB SSD performance
ASRock Z890I NOVA – USB SSD performance
Since the Z890 chipset doesn’t have a native USB4 controller, we use Thunderbolt 4 with USB4 tunneling to perform USB tests. Our USB SSD performs well, and longer tasks have no problems.
Network Performance
LAN
ASRock Z890I NOVA - LAN performance
ASRock Z890I NOVA – LAN performance
The Z890I NOVA uses Realtek 5Gbps LAN, which performs as expected. Since reaching or passing the maximum throughput is impossible, around 4800Mbps looks like an excellent result. We also had no problems with the connection stability during longer work.
WiFi
WiFi results depend heavily on the environment, and the test room is far from perfect: it has thick walls and multiple networks, which limit the bandwidth.
ASRock Z890I NOVA - WiFi performance
ASRock Z890I NOVA – WiFi performance
The direct internet bandwidth is over 900Mbps on average, using a 1Gbps connection, which is pretty good and similar to that of ASRock X870E motherboards reviewed in the previous weeks.
Power Consumption
ASRock Z890I NOVA - Power Usage
ASRock Z890I NOVA – Power Usage
Above, you can see our results for the whole test rig. It’s a typical high-end PC. The NOVA uses slightly less power than ATX models with the same chipset.
Overclocking with the ASRock Z890I NOVA
Intel Core Ultra processors don’t overclock as high as the last Intel generation, and we can count on about 5.6GHz P-cores and 5.0GHz E-cores for an average CPU. Above-average CPUs will give us about 100MHz more. We had no problems reaching 5.6GHz P-cores and 5.0GHz E-cores on the used processor, and the performance is proportionally better than at stock settings. The NOVA has no issues with overclocking or stability, and we couldn’t hear the so-called coil whine before or after overclocking.
ASRock Z890I NOVA - Overclocking
ASRock Z890I NOVA – Overclocking
RAM overclocking seems more exciting. As mentioned earlier, the NOVA has one RAM overclocking profile, 9733MT/s, which works well with our Kingston 8800MT/s memory kit.
We couldn’t reach 10000MT/s, and the limit was 9866MT/s, which wasn’t stable. The overclocking limit is probably caused by the processor and RAM rather than the motherboard. We could still tighten some timings at 9733MT/s. However, I highly recommend going down to around 9000MT/s and setting Gear 2 mode at tight timings. It performs the best on the new Intel generation, and the difference is visible in popular games and other applications.
Even though the Z890I NOVA is a tiny ITX motherboard, it overclocks like a high ATX series on ambient temperatures. ASRock proves once again that it can make great ITX motherboards.
Conclusion
If we are searching for the best ITX motherboard for new Intel processors, then we don’t have a big choice, but at the same time, we have one great option, which is the clear answer for the needs of the most demanding users. The Z890I NOVA meets high expectations regarding design, power delivery, cooling, and stability. The motherboard is also well-equipped with Thunderbolt 4, WiFi 7, a fast M.2 socket, 5Gbps LAN, and other features well-known from high ASRock motherboards.
ASRock motherboards are fully compatible with most RGB devices, such as fans, LED strips, water cooling components, RAM modules, etc. There were also no problems with various RAM kits, regular UDIMMs, or new CUDIMMs. Both series overclocked well.
The ASRock Z890I NOVA costs $299.99 in the Newegg online store. It’s not cheap, but it’s still a very reasonable price for such a good ITX motherboard from the new series.
The Z890I NOVA is another great ASRock ITX motherboard. Whether you are a gamer or a computer enthusiast, you will be delighted with this motherboard, and it fully deserves our Approved Stamp!
Click the stamp for an explanation of what this means.
Bartosz Waluk – Woomack
Related Articles:
Loading new replies...
Avatar of dumpa
dumpa
594 messages 87 likes
Oddly enough, you could get just about any premium Intel board while AM5 boards were selling like crazy.
Reply Like
W
Woomack
Benching Team Leader
13,943 messages 3,382 likes
New AMD motherboards are not selling well, too. They are still selling better than Intel, but many users keep the 600 series because there have been barely any improvements. If someone buys a new PC or upgrades from an old CPU, getting the 800 series AMD or the new Intel is better because of new features and longer support. ASRock has excellent options for both new CPU series, and I haven't seen any problems with availability.
Even though there are mixed comments about the new Intel processors, I find them much better than the last generation. I mean mainly efficiency, temperatures, single-core performance, and improvements in new motherboards.
The tested Z890I NOVA is probably the best ITX motherboard for Arrow Lake processors. There are only a few ITX options on the market, but the NOVA is highly recommended if anyone wishes to build SSF with the new Intel CPU.
Reply 1 Like
