AZZA OPUS 809
Table of Contents
Azza is known for making some of the most unique cases in the PC market. Today, Azza announced the OPUS 809 open-air ATX chassis and it doesn’t dissapoint. The OPUS 809 looks more like modern art than a PC case featuring two aluminum bands for the framework and tempered glass (can be positioned either vertically or horizontally). With support for up to 360 mm long triple-slot GPUs, a 360 mm radiator, and ATX power supplies, the OPUS 809 is a versatile and capable platform. Azza has listed the MSRP at $349.99 and is available through Amazon and Newegg. Please, continue reading Azza’s press release below.
AZZA Rethinks Case Design with the Dual Orientation OPUS 809
Tinted tempered glass panels on 4 sides for a unified look from any angle
Unrestricted airflow from all sides, top, and bottom
Separated compartments for GPU, AIO radiators and PSU offering direct air intake for peak performance
Supports up to 360 radiators and 360mm long triple-slot GPUs with upright GPU bracket
AZZA OPUS 809
December 16th, 2021, Taipei, Taiwan – AZZA, a leading brand of computer cases and accessories, introduces the futuristic high-end OPUS 809. The luxury tower has a minimal footprint of 32cm2 yet capable of supporting full-ATX tower hardware. Flanked by 4 darkly tinted tempered glass panels and built on a 4mm thick CNC milled aluminum frame, the OPUS ensures a unique PC look standing vertical or horizontal, and with its semi-open design, ensures adequate airflow to high-end components up to 360mm long triple slot GPU, 360 AIO, ATX motherboard and PSU, and dual storage drives.
Futuristic Aesthetic with Dual Orientation
Mixing precision and style, the anodized and sandblasted 4mm CNC milled aluminum frame of the OPUS with sharp angles and “X” shape gives the case a futuristic design. Surrounded by 4 tinted tempered glass panels, the OPUS ensures the PC remains elegant no matter which side is exposed. The unique shape and sturdiness of the case allows it to be placed in two orientations, vertically for a minimal 32 x 32cm footprint, or horizontally, changing the look of the PC entirely.
Ingenious Design
The OPUS required rethinking standard case designs. Entirely modular, each panel can be removed to open up access to the inside of the case. The vertical GPU bracket is entirely removable to provide access to the PSU installation, which sits at the bottom of the case. At the rear and away from the motherboard and GPU, the fan/radiator bracket is entirely removable and sits on tracks to ease its installation. Inspired by SFF tower designs, every component is separated and has access to a direct fresh air intake, ensuring peak performance.
Ready for High Performance
The OPUS’ unique form factor doesn’t limit its ability to support large high-performance components. With support from Mini-ITX to ATX motherboards, up to 360mm long triple-slot GPUs, a 360 radiator, ATX PSU, and 2x 2.5” SSDs or 1x 2.5” SDD and 1x 3.5” HDD, users have the possibility to build a powerful PC with modern hardware without holding back.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
In January of this year, In Win announced its first generation of mid-tower gaming cases – the GT1. With an eye on cooling performance, lots of features, and a unique look, In Win hopes to attract the gamer in all of us with an affordable chassis design.
Today on the review table is MSI’s MAG Forge 112R mid-tower chassis. The MAG series are known to be built for gamers and tend to be more budget conscientious. That is exactly where the MAG Forge 112R falls in MSI’s product stack. At just $89.99 at Amazon and Newegg, This feature rich case may have just what you are looking for in your next build. In this review we breakdown each of the features offered by this case as well as testing out its thermal capacity and determine if it’s worthy of the Overclockers.com Stamp of Approval.
Today, we take a look at MSI’s MPG Sekira 100R mid-tower chassis. This is the second review of a series of new MSI cases announced in August, the first being the MSI MPG Gungnir 110R. The Sekira 100R is a gaming chassis that provides a touch of class with its chrome edging, ARGB lighting, and tempered glass front and side panels. It shares many of the great features we loved in the Gungnir 110R with a different aesthetic and several new innovations that caught our attention. Conversely, if you prefer an RGB-less build, be sure to check out the Sekira 100P. It is the same chassis as the Sekira 100R, without all the flashy lights or tempered glass front panel.
Is that a pun on the open air nature of the case? [emoji14]
It certainly has an interesting design. 4mm is pretty thick, but the choice of aluminum over steel give the option to anodized and change the color (either by the home enthusiast or the manufacturer). I still think I might prefer a thinner steel chassis, but only because it would offer a slightly smaller footprint. I fully appreciate that the choice of material and thickness is part of the aesthetic as well functional. I would like this case more as a special order that could add customization. If I could choose designs and have them milled into the aluminum, or have a choice of colors/patterns/hydrodipping then I would be more likely to consider this case, even at a stiff premium.
Just my .02
There are plenty of machine and specialty shops that will do exactly this for a (no so) small price. Hydro dipping can actually be done pretty easily by the end-user too.
Yeah I get that. I'm just saying this particular case would be a bigger draw for me if those options were available from the manufacturer instead of sourcing the work locally. I would settle for different color schemes though
Loading new replies...
1
1
1
1
1
