Table of Contents
Germany’s number one power supply manufacturer, be quiet!, has just announced the new Pure Power 11 FM series power supplies. These fully modular power supplies will available in 550 W, 650 W, and 750W models. All three models utilize a dual-rail 12v delivery system and are 80 Plus Gold rated providing up to a 93.9% efficiency rating. Pricing is not yet available. Also announced are the SFX Power 3 and TFX Power 3 small form factor power supplies. Below are a few quotes from the be quiet! website about the new power supplies.
be quiet! Pure Power 11 FM Series
EXCEPTIONAL QUIET, SUPERIOR FEATURES
Pure Power 11 FM 750W offers peerless dependability and best-in-class features such as modular cable management. Whether you are assembling a very quiet system, upgrading your PC, or building a gaming system with an overclocked high-end GPU: Pure Power 11 FM 750W offers the best combination of features at a very popular price.
- 80 PLUS® Gold efficiency (up to 93.9%)
- Modular cables for maximum build flexibility
- Two strong 12V-rails
- Silence-optimized 120mm be quiet! fan
- Advanced stability and voltage regulation thanks to LLC, SR and DC-to-DC
- Full suite of top safety features
- Five-year manufacturer’s warranty
Pure Power 11 FM 750W is certified 80 PLUS Gold with an efficiency rating of up to 93.9% – a truly outstanding level for this class of PSU. The most compelling benefit: lower power consumption and consequently lower costs, and cooler, quieter operation.
Thanks to the modular cables, all cables that serve no purpose in the system are left out. For this reason, systems always appear very tidy. At the same time installation is performed much more conveniently. A smoother airflow results from the uncluttered layout of the system, which means lower noise and temperatures prevail inside the case.
Pure Power 11 FM offers 750W of continuous power with two independent 12V rails for signal stability and four PCI express connectors. It is suited to very quiet systems, for upgrading or building multimedia, gaming or systems with an overclocked high-end GPU.
The silence-optimized 120mm be quiet! fan is thermally governed to strike the best balance between effective cooling and quietness. Airflow-optimized fan blades reduce turbulence, enabling best-in-class quiet functionality and the almost inaudible operation that be quiet! is famous for.
The use of LLC and Synchronous Rectifier (SR) provides very stable operation and enhanced voltage regulation. The PSU is equipped with DC-to-DC conversion for tight voltage regulation even under heavy cross-loading conditions. This ensures reliable operation with the next generation of processors and graphics cards.
SFX POWER 3
COMPACT AND SILENT ENERGY
SFX Power 3 450W, the first choice compact PSU for mini and media PCs with 80 PLUS® Bronze and PCIe graphics card support. SFX Power 3 450W offers the ideal combination of power, quietness and reliability.
- Strong 12V rail with 450W of continuous power
- Two 6+2 pin PCIe connector for powerful GPUs
- High-quality temperature-controlled 80mm fan for quiet operation of max. 33.8dB(A)
- Sleeved or flat black cables up to 60cm
- 80 PLUS® Bronze efficiency (up to 89.3%)
- Meets the latest safety and efficiency requirements
- Three-year manufacturer’s warranty
- Product conception, design and quality control in Germany
Two PCIe connectors provide power for a demanding and powerful graphics card. Safety protections defend against overcurrents, over- and undervoltages, short circuits and overloads, thus keeping your valuable components safe.
The SFX Power 3 can deliver 450W of continuous power. This ensures a steady and reliable operation even when your PC meets an unexpectedly heavy load.
The high-quality temperature-controlled 80mm fan allows quiet operations of max. 33.8dB(A). The 80 PLUS Bronze certification with an efficiency rating of up to 89.3% is convincing evidence of this PSU’s power saving operation.
TFX POWER 3
TFX Power 3 300W Gold: the upgraded be quiet! high-efficiency PSU for mini and media PCs with 80 PLUS® Gold certification and PCIe graphics card support.
- Certified 80 PLUS® Gold efficiency (up to 91.7%)
- Strong dual 12V-rails for high stability and PCIe graphics card support
- 300W of continuous power
- High-quality temperature-controlled 80mm fan for low-noise operation of max. 21.7dB(A)
- Sleeved or flat black cables up to 60cm long
- Standby draw less than 0.17 watts
TFX Power 3 300W Gold is certified 80 PLUS Gold with an efficiency rating of up to 91.7%. With this outstanding energy efficiency, the TFX Power 3 300W Gold ensures low power consumption and by that lower costs alike.
The dual 12V rail design supports high stability as the CPU receives its power through an independent rail. For demanding peripherals like a graphics card, a PCIe connector is included. This makes the TFX Power 3 300W Gold the ideal PSU for all who strive for enough power to support small systems at low noise.
The temperature-controlled fan ensures a quiet operation and produces little wasted heat. Since TFX Power 3 300W Gold meets the latest safety requirements, it defends the PC system against overcurrents, over- and undervoltage, short circuit, overloads and comparable failures.
Loading new replies...
