Biostar Z590A-Silver
Table of Contents
Today, Biostar announced the new Z590A-Silver motherboard designed for 10th and 11th generation Intel Core processors. Advertised as a highly versatile and robust motherboard, the Z590A-Silver features native PCIe 4.0 including M.2 Gen4, up to 128 GB of DDR4 memory, and a proprietary 14-phase power design. Pricing and availability have not been announced at this time. Please continue reading for additional information and specs from the Biostar press release.
BIOSTAR ANNOUNCES THE LATEST Z590A-SILVER MOTHERBOARD
BEST FOR GAMING AND CONTENT CREATION
Aug 16th, 2021, Taipei, Taiwan – BIOSTAR, a leading manufacturer of motherboards, graphics cards, and storage devices today, unveils the brand new Z590A-SILVER motherboard.
Designed to support Intel’s 10th/11th Generation Intel Core™ Processors and High-end graphics cards, the new Z590A-SILVER motherboard is highly versatile. Powered by Intel’s Z590 single-chip architecture this new motherboard is highly efficient and robust in any use case.
Modern features like PCI-e 4.0 and PCIe M.2 4.0 and other cutting-edge functionality add up to a great platform tailor-made for gaming and content creation. With the support of up to 128 GB of DDR4 memory across 4 DIMM slots and an overclocking capability of up to 5000+(OC) MHz, the Z590A-SILVER motherboard can handle all high-intensive tasks thrown at it.
Backed by BIOSTAR’s proprietary Digital PWM technology and the 14 Phase power design, the new Z590A-SILVER motherboard is safe and long-lasting, capable of supporting the best hardware with ease.
The Z590A-SILVER packs all the essentials in its rear I/O panel. Designed with 8 USB ports consisting of 3 x USB 3.2 (Gen1) Ports, 2 x USB 3.2 (Gen2) Ports, 2 x USB 2.0 Ports and a single USB 3.2 (Gen2x2) Type-C Port. Furthermore, a single 1 x PS/2 Keyboard / Mouse Port provides extra connectivity to connect an older device into the system.
Additionally, 2 x WiFi Antenna ports that support WiFi 6 and a single LAN port powered by Realtek RTL8125B chipset are readily available for faster internet connectivity.
For video output, the motherboard comes with a single DVI-D port, a single DP-Out port in addition to an HDMI 2.0 port capable of supporting up to 4k vivid crystal-clear images. Three powerful audio ports controlled by the ALC1220 chipset provide an immersive audio-visual experience with 7.1 Channels, High-Definition Audio output.
BIOSTAR’s globally renowned product quality carries on with their new Z590A-SILVER motherboard. Engineered with the best features and functionality, this new motherboard brings Reliability, performance, and cutting-edge technology into the hands of consumers making it the best choice for any business or casual use.
Spec Table
Model
Z590A-SILVER
Chipset
Intel Z590
CPU SUPPORT
Support for 10th/ 11th Generation Intel Core™ i9/ i7/ i5/ i3 processors and Intel Pentium processors/ Intel Celeron processors in the LGA1200 package
* Please refer to www.biostar.com.tw for CPU support list.
MEMORY
Supports Dual Channel DDR4 5000+(OC)/ 4333(OC)/ 4266(OC)/ 4133(OC)/ 4000(OC)/ 3866(OC)/ 3800(OC)/ 3733(OC)/ 3600(OC)/ 3200/ 2933/ 2800/ 2666/ 2400/ 2133
4 x DDR4 DIMM Memory Slot, Max. Supports up to 128 GB Memory
Each DIMM supports non-ECC 4/ 8/ 16/ 32GB DDR4 module
Support Intel Extreme Memory Profile (XMP) memory modules
* Please refer to www.biostar.com.tw for Memory support list.
STORAGE
— Total supports 3 x M.2 socket and 6 x SATA III (6Gb/s) ports
6 x SATA III Connector (6Gb/s) : Supports AHCI, RAID 0, 1, 5, 10 & Intel® Rapid Storage Technology
1 x M.2 (M Key) Socket (M2_PCIEG4_64G_11TH_ONLY):
Supports M.2 Type 2280 SSD module
Supports PCIe 4.0 x4 (64Gb/s) – NVMe/ AHCI SSD
Support 11th Gen processor only
1 x M.2 (M Key) Socket (M2_PCIEG3_32G_SATA_RST_1):
Supports M.2 Type 2260/ 2280 SSD module
Supports PCI-E 3.0 x4 (32Gb/s) – NVMe/ AHCI SSD & SATA III (6Gb/s) SSD
Supports Intel Rapid Storage Technology and Intel Optane Technology
1 x M.2 (M Key) Socket (M2_PCIEG3_32G_RST_2):
Supports M.2 Type 2242/ 2260/ 2280/ 22110 SSD module
Supports PCIe 3.0 x4 (32Gb/s) – NVMe/ AHCI SSD
* M.2 (M Key) Socket (M2_PCIEG4_64G_11TH_ONLY) support 11th Gen Rocket Lake-S CPU only.
* When using SATA SSD module on M.2 slot(M2_PCIEG3_32G_SATA_RST_1), the SATA_6 connector will be disabled.
LAN
Realtek RTL8125B
10/ 100/ 1000/ 2500 Mb/s auto negotiation, Half / Full duplex capability
AUDIO CODEC
ALC1220
7.1 Channels, High Definition Audio, Hi-Fi(Front)
USB
1 x USB 3.2 (Gen2x2) Type-C port (1 on rear I/O)
2 x USB 3.2 (Gen2) ports (2 on rear I/Os)
5 x USB 3.2 (Gen1) ports (3 on rear I/Os and 2 via internal header)
6 x USB 2.0 ports (2 on rear I/Os and 4 via internal header)
EXPANSION SLOT
2 x PCIe 3.0 x1 Slot
1 x PCIe 4.0 x16 Slot (x16 mode)
1 x PCIe 3.0 x16 Slot (x4 mode)
* According to different CPUs will have different speeds.
* PCIe 4.0 speed only for INTEL 11th Gen CPUs.
REAR I/O
2 x WIFI Antenna Ports
1 x PS/2 Keyboard/ Mouse Port
1 x HDMI Port (HDMI2.0)
1 x DP Port
1 x DVI-D Port
1 x USB 3.2 (Gen2x2) Type-C Port
3 x USB 3.2 (Gen1) ports
2 x USB 2.0 ports
1 x 2.5 GbE LAN port
3 x Audio Jack
INTERNAL I/O
6 x SATA III Connectors (6Gb/s)
1 x M.2 (E Key) Socket : Supports 2230 type Wi-Fi & Bluetooth module and Intel CNVi
2 x USB 2.0 Headers (each header supports 2 USB 2.0 ports)
1 x USB 3.2 (Gen1) Header (each header supports 2 USB 3.2 (Gen1) ports)
1 x 4-Pin Power Connector
1 x 8-Pin Power Connector
1 x 24-Pin Power Connector
1 x CPU Fan Connector
1 x CPU water cooling connector (CPU_OPT)
3 x System Fan Connectors
1 x Front Panel Header
1 x Front Audio Header
1 x Internal Stereo Speaker Header
1 x Clear CMOS Header
1 x COM Port Header
1 x TPM Header
1 x Thunderbolt 3 Header
2 x LED Headers (5V)
1 x LED Header (12V)
* M.2 (E key) Wi-Fi card is not provided
DIMENSIONS
ATX Form Factor Dimension: 30.5 cm x 24.4cm ( W x L )
OS SUPPORT
Supports Windows 10(64bit) / 11(64bit)
※Biostar reserves the right to add or remove support for any OS with or without notice.
ACCESSORIES
4 x SATA Cable
1 x I/O Shield
1 x DVD Driver
1 x User Manual
ABOUT BIOSTAR
BIOSTAR, is a professional brand dedicated to the production of motherboards, gaming motherboards, SSD, graphics cards, industrial computing systems, IoT, crypto mining equipment, healthcare solutions and motor start battery. Since its establishment in 1986, BIOSTAR has become a major motherboard supplier in the IT industry. In order to pursue the best quality and aesthetic design, BIOSTAR has invested heavily in ID design, equipment, global marketing research as well as R&D. With a constant emphasis on quality, BIOSTAR always seeks to improve beyond better and race to the future.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Today we are going to get a chance to review Intel’s next processor in their High-End Desktop (HEDT) platform. The king of the consumer hill used to be the mighty i7-5960X our friend Dino reviewed back in August of 2014. That ‘extreme’ CPU shook up the landscape then by providing the consumer with a high clocked, octo-core CPU with a total of 16 threads. Since then Intel brought to market their 14 nm Broadwell CPU architecture, on their mainstream platform, through their “tick-tock” cycle. Naturally, the next HEDT processor is based off the same 14nm lithography, Tri-gate(FinFET) technology is Broadwell-E. Broadwell-E, specifically the i7-6950X, brings us our first deca-core processor which isn’t based on the Xeon or Opteron platforms.
It’s all about the audio my friends, BIOSTAR’s Puro Hi-Fi audio to be exact. The idea behind this motherboard is to attract the overclocker, the gamer, the audiophile, and those that might be looking for a HTPC motherboard solution. Sounds like pretty high expectations, so let’s carry on and see what the BIOSTAR Hi-Fi Z77X brings to the table.
Loading new replies...
