ASRock has joined the party, announcing several new Z590 motherboards for CES 2021, joining the likes of ASUS and BIOSTAR. The 500 series lineup from ASRock spans entry-level all the way to bleeding edge performance. The flagship ASRock Z590 Taichi and Z590 PG Velocita both feature Killer WiFi and Lighting USB Gaming Ports designed for use with the latest ultra-high poll rate gaming peripherals. Rounding out the lineup are the mainstream Z590 Pro4 ATX and Z590M Pro4 micro-ATX motherboards.
See full press release below:
Rock It! ASRock Launches Full Range of Intel 500 Series Motherboards with Best-in-Class Features
TAIPEI, Taiwan, January 12th, 2021 – The leading global motherboard manufacturer, ASRock, proudly announces its comprehensive new range of motherboards featuring Intel® 500 series chipsets, supporting current 10th Generation Intel® CoreTM Processors and new 11th Generation desktop processors enabling PCI-Express Gen-4.
ASRock Flagship Motherboards
Designed for the premium market, the “uncompromised performance” ASRock Z590 Taichi embraces the latest USB4 standard with Thunderbolt 4 technology, providing an incredible 40Gb/s transfer rate that is perfect for ultra-high speed external storage devices.
Killer WiFi connectivity features the latest WiFi 6E standard, which embraces the 6GHz band for extreme throughput performance and the lowest latency. Together with its Killer LAN onboard, Killer Double Shot can be used to combine both connections together, maximizing networking performance.
New features added to ASRock’s premium 500 series motherboards include the Lightning Gaming Ports that uniquely use custom engineered USB signal lanes to accommodate the latest gaming mice with ultra-high polling rates; whereas traditional USB signal design cannot fully support this high report rate gaming peripheral therefore limits performance.
Showcasing its true, gaming-focused design, the Z590 PG Velocita incorporates the CPU Direct Source LAN. Unlike others that are gaming in name only, the Killer E3100 2.5G LAN chip on the ASRock Z590 PG Velocita can be controlled directly by the CPU, providing the lowest possible latency and significant overall networking performance boost, ensuring users always have the edge in battle with the lowest pings possible.
ASRock Steel Legend Series
Memory overclocking is now available on all ASRock Z590, H570 and B560 motherboards, giving more users the best performance potential. All Steel Legend motherboards use a 6-layer PCB for optimized signal and power tracing, lowers board temperature as well as improving memory stability at higher frequencies, and further overclocking potential.
Every motherboard in this series is equipped with 2.5Gb/s LAN and a front panel USB 3.2 Gen-2×2 header. 2.5Gb/s LAN boosts networking performance 2.5X over typical home ethernet speeds. It is ideal for home NAS streaming and backups, content creators, online gamers, and the demands of enthusiasts for lower-latency gaming, faster file transfers and performance that keeps up with modern SSDs. Similarly, USB 3.2 Gen-2×2 is capable of 20Gbps throughput, providing the most convenient access for USB storage devices in need of extreme speeds.
A graphics card holder is bundled with all ASRock Z590 mainstream to high-end motherboards. Its universal design ensures heavy graphics cards can be held securely in the chassis. Simply attach it to your motherboard and chassis with the provided screws, and then slide the holder to the required height of your graphics card.
ASRock Pro4 Series for Mainstream Builders
ASRock is keen to support all PC builders, from premium to entry level. The Z590 Pro4 (ATX) and Z590M Pro4 (micro ATX) both use a 6 layer PCB and 12 phase Dr.MOS VRM, bringing incredibly powerful performance and superb overclocking potential to more users than ever. Dr.MOS fully integrated MOSFETs operate more efficiently than alternative solutions, enabling lower temperatures and improved sustained performance.
Bringing PCIe Gen-4 to Everyone
ASRock is bringing the benefits of PCIe Gen-4 to everyone, from premium to entry level. All ASRock B560 motherboards include at least one PCIe Gen-4 x4 M.2 SSD slot (when 11th Gen Intel Core Processors are used), embracing the latest PCIe Gen-4 SSD devices with the best performance for the widest number of PC builders. Even the entry B560M-HDV offers two M.2 Key-M slots, provided by PCIe lanes from CPU and chipset respectively.
With a wide range of options available including everything from entry to premium, mini-ITX, mATX and ATX, look no further because the ASRock 500 series motherboards bring incredible performance, best-in-class features, and stylish designs throughout its comprehensive range.
Stay glued to Overclockers.com for more CES 2021 coverage!
Loading new replies...
