Earlier today, Cooler Master announced for preorder two brand new mATX ARGB towers: the MasterBoxMB311L ARGB (Mesh Front Panel) and MasterBox MB320L ARGB (Acrylic Front Panel). Each of these cases includes two ARGB Fans and tempered glass side panel and at a price point of $59.99 they are poised to target the budget PC builder who still wants some bling. We’ve compiled a list of specifications for both of these new models below. The main difference between these two models is the ability to choose either better airflow or striking looks with the mesh front panel or the DarkMirror acrylic front panel.
Specifications
MODEL NUMBER
MCB-B320L-KGNN-S01, MCB-B320L-KGNN-S02
MCB-B311L-KGNN-S01, MCB-B311L-KGNN-S02
SERIES
MasterBox Series
MasterBox Series
SIZE
Mini Tower
Mini Tower
AVAILABLE COLOR(S)
Black
Black
MATERIALS
Plastic, Tempered Glass, Mesh
DIMENSIONS (L X W X H)
435.5 x 217.5 x 410mm, 366.5 x 210 x 400mm
WEIGHT
5.47kg
5.47kg
MOTHERBOARD SUPPORT
Micro ATX, Mini ITX
Micro ATX, Mini ITX
EXPANSION SLOTS
4
4
2.5″ / 3.5″ DRIVE BAYS (COMBO)
2
2
2.5″ DRIVE BAYS
2
2
I/O PANEL
2x USB 3.2 Gen 1, 1x 3.5mm Audio Jack, 1x 3.5mm Mic Jack, 1x ARGB 2-to-3 splitter, 1x ARGB Controller (only for the S02 versions)
PRE-INSTALLED FANS – FRONT
2x 120mm ARGB Fan
2x 120mm ARGB Fan
FAN SUPPORT – TOP
2x 120/140mm
2x 120/140mm
FAN SUPPORT – FRONT
3x 120mm, 2x 140mm
3x 120mm, 2x 140mm
FAN SUPPORT – REAR
1x 120mm
1x 120mm
RADIATOR SUPPORT – TOP
120mm, 240mm
120mm, 240mm
RADIATOR SUPPORT – FRONT
120mm, 140mm, 240mm, 280mm
RADIATOR SUPPORT – REAR
120mm
120mm
CLEARANCE – CPU COOLER
166mm/6.54″
166mm/6.54″
CLEARANCE – PSU
140mm (HDD cage in backmost position), 325mm (w/o front radiator & HDD cage)
CLEARANCE – GFX
344mm
344mm
CABLE ROUTING
18-22mm
18-22mm
DUST FILTERS
Top, Bottom, Front
Top, Bottom, Front
POWER SUPPLY SUPPORT
Bottom mount, ATX
Bottom mount, ATX
WARRANTY
2 years
2 years
These are available for purchase/preorder on Amazon today.
LOS ANGELES, CALIF., FEB. 11, 2020 – Cooler Master today announces two mATX ARGB Towers: the MasterBox MB311L ARGB (Mesh Front Panel) and MasterBox MB320L ARGB (Acrylic Front Panel). Following in the principles of the award-winning MB Series, versatility is paired with presentation to ensure that any gaming system built inside the MB300 series looks as good as it performs.
MasterBox MB311L ARGB: Mesh Front Panel
The MasterBox MB311L ARGB is a Micro-ATX airflow PC case pre-installed with two ARGB fans and made to be built with the latest gaming hardware. The front panel’s facade is made entirely of Fine Mesh, placed between two honeycomb vents on either side to maximize airflow.
MasterBox MB320L ARGB: DarkMirror Acrylic Front Panel
The MasterBox MB320L ARGB is a Micro-ATX PC case with two pre-installed ARGB fans and honeycomb mesh ventilation on either side of the DarkMirror front panel. The DarkMirror acrylic front panel is smoked a shade darker to sharpen the contrast of the ARGB fans pre-installed behind it, highlighting its best features.
Tempered Glass and ARGB on-a-Budget
The case includes a tempered glass side panel and two pre-installed 120mm ARGB fans for $59.99 – ideal for builders on a budget.
Pricing & Availability
The MasterBox 311L ARGB and MasterBox 320L ARGB are available for preorder on Amazon for $59.99
AMD did OK last quarter. They went from a slight loss to a slight profit. Again, like last quarter, AMD’s flash memory served as an anchor on earnings. It lost $90 million this quarter, which was better than the $110 Read More
Discussion
