Corsair TwinX1024-3200LLPRO
A Gig of the Good Stuff – Brian Berryman
SUMMARY: A “Gig” of the Good Stuff
Today, we’re going to take a look at some DDR400 speed memory, which the good folks over at Corsair
were kind enough to send out to us.
Corsair sent us one of their Corsair TwinX1024-3200LLPRO
high speed, low latency memory kits to take a look at.
LLPRO
Image courtesy of Corsair
I’ve been using Corsair memory in my main/gaming machine for quite some time now (refer back to any of my article reviews in the recent past…you’ll see it in the background
of quite a few pictures).
The ram I have been running is their CMX-512 PC3200C2 revision, using a pair of these
in Dual Channel mode on my Abit NF7-S v2.0 motherboard.
While these two older sticks of ram weren’t a matched set like the LLPRO we’ll look at today, they work perfectly in DC mode.
In the process of reviewing Corsair’s newer version of their PC3200 memory here, we’ll be taking a fairly good look at the older C2 spec ram as well, comparing the two revisions.
In the package:
The lone “accessory” included with the kit is a Powered by Corsair window decal. There’s no coupons for Half Life 2, or rounded cables, but then, when you make some of the
best memory on the planet, you don’t need extras.
The sticker on the heat spreader, close up.
Of note above, in the lower right corner, is the number 2326. These are the timings (set in the motherboard’s BIOS) that this memory runs at, at default speed.
In testing these out, I found that they will actually run at tighter settings, at 6-2-2-2. I’ve read reports of some users getting these to run even lower than that, to 5-2-2-2. I did try this
setting out, and my PC wouldn’t boot. I did run them through their paces, starting at the default settings, and working my way up. This ram overclocked quite nicely in my system.
Too nicely, as we’ll see shortly.
The new PRO Series from Corsair now incorporates activity LEDs into the spine of the heat spreader. These aren’t just a gimmick, they actually work, and work well.
In the process of testing various settings (when really pushing my system hard), I did lock up the rig hard a couple of times. Looking through the window in my side panel at these
LEDs were a very quick visual cue that something was amiss, as they weren’t blinking. The page at Corsair linked to above (2nd link at top) includes a Macromedia Flash presentation of them in action.
Here is a static (still) image of them:
Installed
There are 18 LEDs in each module, which light up green, yellow and red depending on the amount of memory being accessed.
The effect visually is not unlike a stereo graphic equalizer. Green to red, with red indicating highest activity.
It was quite interesting to watch these lights as I ran the benchmarks I’ll get to shortly, as they visually showed how much ram was being used during testing.
Specifications and Features; TwinX1024-3200LLPRO
  • Tested (and packaged in pairs) at DDR400 at ultra low latency settings (2-3-2-6)
  • SPD programmed at advanced 2-3-2-6 values
  • 1024 MB total (two DIMMS of 512 MB each per kit)
  • New high efficiency aluminum XMS heatsink
  • 18 activity LEDs (per DIMM) show level of memory activity
  • Benchmarked over multiple chipsets, processors, and motherboards
  • Lifetime warranty
The Test System:
For these tests, I used my AMD based system. The motherboard decided to stop working recently in my Intel machine, so until I can replace the board, the AMD rig is it.
This machine has been used in most of my hardware reviews (in addition to that now defunct Intel P4 machine), and there’s only been one change since the last reviews, that
being an upgrade to the hard drive. The major parts in this machine are:
  • AMD XP2100+ Thoroughbred “B” cored CPU
  • Abit NF7-S v2.0 motherboard
  • 160GB (8 MB cache) Maxtor ATA133/7200 RPM Hard drive (IDE)
  • BFG Technologies (nVidia) Geforce 4 Ti4200 (4x AGP, 128MB ram)
  • Custom made watercooling system built by me
Since the system build article I just linked to was written, I’ve changed over to a DangerDen Maze 4 waterblock. At this time, the northbridge chipset block has been taken out,
replaced by a Swiftech MCW50-T on the graphics card GPU. I also upgraded the PSU from the 420W unit mentioned, to a 550W unit.
The Benchmarks Used:
In testing these sticks of memory out, I used three commonly used benchmarking suites:
** Futuremark has discontinued support for PC Mark 2002. It is still available for download however, at Futuremark’s website.
{mospagebreak}
A quick overview of the CMX-512 PC3200C2:
C2
  • 100% tested at 200FSB (DDR400) on high performance motherboards
  • SPD programmed at JEDEC standard values
  • Tested at 2.5-3-3-6 on AMD systems
  • Integrated aluminum heat spreader for improved thermal performance
  • Lifetime warranty
While the latency rating for these sticks is higher, I was still able to get them to run at 6-3-2-2 at 200FSB. I did have to relax those timings much sooner than the
newer LLPRO version however, as we will see below.
On to the benchies!
The methodology I used in testing these out was, that I raised the voltage to them only as a last resort, to try to remain stable, as I increased the FSB.
All runs were done at a 1:1 ratio with the CPU (synchronously). I’ll notate as we go along anywhere I needed to change any settings. I usually run the XP2100+ at a multiplier of
11x. As the FSB went up, I had to back that down to 10.5x to keep the CPU stable. I also wound up increasing the CPU core voltage at one point, as well.
All of the tests were run a minimum of three times through, frequently more. Basically, I ran them until the numbers stopped going up, and either leveled off, or a
run produced a lower result than the previous run did.
All runs were also done in Dual Channel mode, with the sticks installed in DIMM slots #2 and 3.
200 FSB (DDR400) Baseline
CPU @ 11 x 200 = 2200MHz @ 1.75v
Business as usual, for both sets of ram here. Note that the 3200C2 is actually running at tighter than spec latency settings of 6-3-2-2.
PC3200C2
PC3200LLPRO
Latency settings
6-3-2-2
6-3-2-2
Voltage
2.6v
2.6v
Sandra 2004 Memory Bench Integer ALU
2923 MB/s
2923 MB/s
Sandra 2004 Memory Bench Float FPU
2756 MB/s
2751 MB/s
PC Mark 2002 CPU score
6471
6477
PC Mark 2002 Memory score
5150
5140
PC Mark 2004
3518
3517
Ran stable?
Yes
Yes
Pretty even, across the board, which it should be, with both sets running identical specs.
Note: While the voltage was set in the BIOS to 2.6v (the lowest setting available), both Sisoft Sandra and Motherboard Monitor 5 showed it at 2.72v. It appears the Abit
NF7-S overvolts the ram slightly.
205 FSB (DDR410)
CPU @ 11 x 205 = 2255MHz @ 1.75v
The older C2 revision got shaky running the tight timings at 205, and I had to back the settings off a bit. After doing that, it ran 205 very stably.
The LLPRO sailed through these tests handily, with no changes.
PC3200C2
PC3200LLPRO
Latency settings
7-3-3-2.5
6-3-2-2
Voltage
2.6v
2.6v
2963 MB/s
3000 MB/s
2779 MB/s
2825 MB/s
6623
6640
5230
5286
PC Mark 2004
3628
3628
Ran stable?
Yes
Yes
Here we start seeing the two revisions breaking away from each other, due to the latency timings used. Note also, that the CPU score in PC Mark 2002 was also
effected by this change. Oddly, the PC Mark 2004 scores don’t reflect the different settings here at 205 FSB.
207 FSB (DDR414)
CPU @ 11 x 207 = 2277MHz @ 1.75v
No settings changes here, other than the increase in FSB.
PC3200C2
PC3200LLPRO
Latency settings
7-3-3-2.5
6-3-2-2
Voltage
2.6v
2.6v
3004 MB/s
3031 MB/s
2815 MB/s
2853 MB/s
6699
6703
5282
5328
PC Mark 2004
3648
3664
Ran stable?
Yes
Yes
Noteworthy here is that the C2 scores at 207 are just about equal to the LLPRO scores at 205, meaning the difference in latency is roughly equivalent to 2 FSB. We start
seeing a difference in the PC Mark 2004 scores here, as well.
210 FSB (DDR420)
CPU @ 11 x 210 = 2310MHz @ 1.75v
PC3200C2
PC3200LLPRO
Latency settings
7-3-3-2.5
6-3-2-2-
Voltage
2.6v
2.6v
3039 MB/s
3072 MB/s
2878 MB/s
2892 MB/s
6782
6798
5352
5396
PC Mark 2004
3709
3721
Ran stable?
Yes
Yes
Here we can see the difference in latency increases the margin in the scores further with the higher FSB setting. The tighter timings are now about equal to 3 FSB (the C2 scores at 210 equal the LLPRO scores at 207).
213 FSB (DDR426)
CPU @ 11 x 213 = 2343MHz @ 1.75v
Things did start getting a bit unsteady here at these settings, but that was due to my CPU getting close to maxed out. I know it peaks somewhere around this speed, and it showed in this round of tests.
Both sets of ram ran the tests fine, but afterwards, when just running normal applications using the C2, I got kicked out of Unreal Tournament 2004 to the desktop after about 30 minutes.
The LLPRO didn’t do this, but was acting quirky, with things loading slowly, etc. No applications crashed, but it was obvious something wasn’t “right”, either.
The LLPRO is still running at default latency settings here at 213FSB.
PC3200C2
PC3200LLPRO
Latency settings
7-3-3-2.5
6-3-2-2
Voltage
2.6v
2.6v
3073 MB/s
3083 MB/s
2878 MB/s
2903 MB/s
6865
6860
5411
5367
PC Mark 2004
3725
3745
Ran stable?
Yes/no**
Yes/no**
** The instability here wasn’t a result of the memory settings, but rather the CPU hitting it’s limit at the settings used for it.
Interestingly, the C2 scored higher in a few of the tests here, for reasons we’ll see next (below).
215 FSB (DDR430)
(LLPRO) CPU @ 11 x 215 = 2365MHz @ 1.9v
(C2) CPU @ 10.5 x 215 = 2257MHz @ 1.9v
215 FSB required a host of changes to run, not only for the memory, but the CPU as well. The system blue screened until I raised the CPU voltage to a higher setting, so I pushed
it up to 1.9v. While this got the system to boot properly, things were still unsteady after that.
The C2:
With the bump in CPU voltage, I was able to get through the tests the first time alright, but was kicked out of UT2004 instantly, back to the desktop. At this point with the C2,
I had to drop the CPU speed via the multiplier back to 10.5x (at 215 FSB). I reran the tests, and PC Mark 2004 would not finish, kicking me out in the DiVX Rendering test.
I then raised the voltage to the DDR for the first (and only time) to 2.7v (Sandra and MBM5 reported this as 2.83v). At these settings it was extremely stable.
The LLPRO:
At 215FSB, the LLPRO finally said “No MAS!” to the tight latency settings, as the machine refused to boot up at them. Dropping the timings to 7-3-3-2.5 regained stability with the
LLPRO, at an 11x multiplier. I didn’t have to change the CPU speed with the LLPRO at 215, the CPU voltage and latency changes were enough to keep it stable.
Note the extra entries below regarding CPU speed.
PC3200C2
PC3200LLPRO
Latency settings
7-3-3-2.5
7-3-3-2.5
Voltage
2.7v
2.6v
CPU Setting
10.5x (2257MHz)
11x (2365MHz)
3130 MB/s
3122 MB/s
2913 MB/s
2927 MB/s
6648
6951
5327
5480
PC Mark 2004
3603
3784
Ran stable?
Yes
Yes
With the latency settings back to equal, the scores in Sandra 2004’s Memory Bandwidth tests reflect this change, as they even out again.
The scores in both Futuremark suites reflect the differences in CPU speed above, with the C2 scores taking a plunge due to the lower CPU speed.
{mospagebreak}
217 FSB (DDR434)
CPU @ 10.5 x 217 = 2279MHz @ 1.9v
At this point, I had to drop the CPU multiplier with the LLPRO, as it again would not boot. This instability was entirely a CPU thing, as going to a 10.5x multiplier
resulted in a very stable system. Note however, it’s still running the default voltage (or at least, the lowest I could set it for (2.6v)).
PC3200C2
PC3200LLPRO
Latency settings
7-3-3-2.5
7-3-3-2.5
Voltage
2.7v
2.6v
3166 MB/s
3165 MB/s
2951 MB/s
2949 MB/s
6712
6709
5423
5416
PC Mark 2004
3675
3665
Ran stable?
Yes
Yes
Once again, pretty even, across the board, which it should be, with both sets running identical specs.
This was the last fully stable set for the C2. The LLPRO was totally stable here, once the CPU speed had been decreased.
220 FSB (DDR440)
CPU @ 10.5 x 220 = 2310MHz @ 1.9v
With the CPU speed again cresting 2.3GHz, things stated getting skittish again testing with the C2. It started out by loading WinXP Pro a bit rough, and wouldn’t finish the PC Mark
2004 suite, locking the machine up hard.
I then tried changing the timings for the C2 to 8-4-4-3, which wouldn’t POST. I then went back in, put the timings back, and tried 2.8v to the memory. This booted.
Once I got into Windows, I immediately ran the PC Mark 2004 suite again, which it again didn’t finish, with Internet Explorer crashing in the Web Page Rendering test.
I finally tried dropping the CPU multiplier to 10x (10 x 220 = 2200MHz), which I really didn’t want to as the scores would take a nose dive across the board, basically hitting
the wall of diminishing returns. I tried it nonetheless, and it again failed in the Web Page Rendering test in PC Mark 2004.
The partial scores shown here are from the incomplete set when it locked up hard in PC Mark 2004.
The LLPRO was completely stable at these settings.
PC3200C2
PC3200LLPRO
Latency settings
7-3-3-2.5
7-3-3-2.5
Voltage
2.7v
2.6v
3203 MB/s
3213 MB/s
2985 MB/s
3000 MB/s
6819
6807
5470
5482
PC Mark 2004
LOCKED UP
3713
Ran stable?
NO
Yes
At this point, the C2 was all in, as I couldn’t complete the benchmarks at all, despite increasing the voltage, relaxing the timings, and reducing the CPU speed yet further.
Whereas the C2 had so much difficulty with these settings, I ran the LLPRO here for a full day after running the benchmarks, just doing my usual things.
It never once showed any signs of instability at this speed.
222 FSB (DDR444)
CPU @ 10.5 x 222 = 2331MHz @ 1.9v
222
The above screenshot was taken with Arthur Liberman’s GCPUID utility, which can be found HERE.
Look for a review of this utility, and other applications of Mr. Liberman’s in the near future.
No settings changes here for the LLPRO, other than the increase in FSB.
PC3200C2
PC3200LLPRO
Latency settings
NO POST
7-3-3-2.5
Voltage
2.6v
3246 MB/s
3026 MB/s
6884
5530
PC Mark 2004
3751
Ran stable?
Yes
This set was the last fully stable set with the LLPRO. This indicates to me that more than likely the motherboard is holding me back once I pass this high a FSB setting.
223 FSB (DDR446)
CPU @ 10.5 x 223 = 2342MHz @ 1.9v
At 223FSB, the machine started acting flaky when booting into Windows. It only completed part of the tests, failing in the PC Mark 2004 Web Page Rendering test again.
At this point, I tried rasing the voltage to the LLPRO (the first and only time I did this), to no avail. It again failed at the same test in PC Mark 2004.
I’m uncertain whether or not this is my CPU, or motherboard stumbling here, but I’m guessing motherboard, judging by the way things transpired with the C2 at 220FSB, where I
lowered the multiplier and it was ineffective.
The computer was stable at this speed (2340MHz) at a different multiplier and FSB combination, which really leads me to believe it to be the motherboard signing off for the
evening at about 222FSB.
PC3200C2
PC3200LLPRO
Latency settings
7-3-3-2.5
Voltage
2.6v
3412 MB/s
3181 MB/s
7203
5795
PC Mark 2004
DNF
Ran stable?
NO
While incomplete, these numbers were the highest I achieved in the Sandra 2004 Memory Bandwidth and PC Mark 2002 tests, by a very wide margin (even over 222FSB).
223
It gave me the impression that this ram was just getting started, as the rest of my system decided it had had enough.
225 FSB (DDR 450) x 10.5, 1.9v CPU, 2.7v DDR, 7-3-3-2.5 blue screened before ever seeing Windows.
Coupled with the fact that at DDR446, I was still running at the lowest available voltage, and fairly tight timings of 7-3-3-2.5. I feel I left a lot of this memory on the table,
unable to fully wring it out with this system.
I’d be very curious as to how it would fare in an 800FSB P4 system, which I think would truly give this memory a run for it’s money.
CONCLUSIONS
On the back of the TwinX1024-3200LLPRO packaging, are a number of quotes from previous reviews of Corsair products. One of them, taken from a review at
Bit-Tech.net, the reviewer states:
“The problem with this Corsair XMS Memory is not how far you can push it, but finding system components that can keep up with it!”
(Macroman, Aug 3, 2002, in a Bit-Tech.net review of Corsair XMS PC3200 memory)
This seem to be the exact issue I faced here, with these sticks of PC3200LLPRO. I feel certain they had more to give, but the balance of my system just wouldn’t carry them there.
This product impressed me, as I was able to push my system farther than it had ever gone previously, getting higher benchmark scores than I’d never seen before.
The embedded Activity LEDs, while at first glance seem kind of gimmicky, function very well. Depending on what you’re doing with the PC, you really can tell how much memory
is being accessed by way these light blink on and off. And, if you happen to push your system a bit too hard, they’re a quick indicator of a system lockup. If they’re not blinking at all,
you can be pretty sure something is amiss.
If you’re running an AMD Socket “A” based system, this would make a fine choice for your memory needs. Indeed, with any system really. With a Socket “A” system, this memory will likely
outpace the rest of your system. A Pentium 4 or AMD 64/FX based system would likely push this product further than I was able to here.
Their older CMX-512 PC3200C2 is a very good product as well, but was outperformed by the newer revision in these tests.
I’d like to thank Corsair for sending this memory kit out for us to evaluate today.
Cheers!
Email Brian
Be the first to comment
Leave a Reply
