EK and PowerColor Unleash Liquid Devil AMD Radeon RX 7900 XTX GPU
EKWB
EKWB
EKWK and PowerColor have partnered up once again, bringing exceptional cooling to the Liquid Devil RX 7900 XTX GPU. The Liquid Devil series graphics cards use only the top-binned GPU processors and are paired with a 17-phase VRMs. The core clock can reach up to 2,680 MHz in “Unleash Boosted Mode” and features 24GB of GDDR6 memory. Additionally, the nickel-plated electrolytic copper block reduces the thickness from a large 3-slot card down to just a single slot. The top of the block is Acrylic and POM acetal affording a phenomenal aesthetic. Price and availability were not included in EKWB’s press release, but you can expect it to fetch quite a bit more over the card itself.
EK®, the premium liquid cooling gear manufacturer, has once again partnered with PowerColor®, the exclusive supplier of graphics cards powered by AMD’s graphics processors, to bring you a factory water-cooled Radeon™ RX 7900XTX GPU. This card’s water block allows it to easily reach peak performance while having a single-slot design for the flexibility to fit inside any case and on vertical GPU mounts.
PowerColor Liquid Devil Radeon RX 7900 XTX
This prestigious Liquid Devil series GPU uses only pre-binned graphics card chips with the highest quality silicon to achieve the best graphics core frequencies. These chips are installed on a brand new 14-layer PCB, equipped with a 17-phase VRM power delivery system consisting of DrMOS and high polymer capacitors. The VRAM on this graphics card has its own 4 phases in the VRM for clean power delivery. New IMON technology monitors and reports each phase’s electric current and power consumption. By balancing the workload, the Liquid Devil ensures unparallel stability and thermal protection while pursuing its overclocking potential.
On the thermal front, to ensure these lightning-fast graphics processors hit their maximum clocks, a unique EK water block is pre-installed, prolonging the card’s lifespan with superior thermals that only liquid cooling can provide. This also ensures no precious gaming time is spent on the water block mounting, and there are no questions regarding the warranty.
An easily accessible switch allows users to quickly choose between two onboard BIOSes and opt for either the OC mode, which provides high performance with balanced power usage, or the Unleash mode, which is designed for breaking records.
The base of the block is made of nickel-plated electrolytic copper, while its top is made of glass-like Acrylic and durable black POM acetal. High-quality EPDM O-Rings ensure sealing.
The visual appearance of the graphics card undeniably backs up the Devil gaming pedigree.
The distinctive and unique water block cover is partly accented with an acrylic design, enhanced by the subtle back glow that adds a mystic ambiance to match any desired gaming mood. The lighting is fully addressable, allowing various effects through PowerColor’s DevilZone FAN RGB control utility.
EK Loop Leak Tester
EK Loop Leak Tester
This gaming graphics card is also delivered with an EK-Loop Leak Tester Flex.
It provides a fast and safe way to test for possible leaks in your liquid cooling loop. While traditional leak testing works, it requires hours before very small leaks can be detected, and then things can become messy. EK-Loop Leak Tester Flex does the job within minutes without risking any actual leakage.
Liquid cooling brings lower temperatures, ensuring the card’s native GPU Boost overclocks it to levels that are out of reach for traditional air cooling. All that with a prolonged lifespan and significantly less noise pollution when connected to the existing or new custom loop system.
Take full advantage of the RDNA architecture that is powering this AMD gaming GPU. Equipped with GDDR6 memory and featuring PCI Express 4.0 support, RDNA architecture is ready for the latest generation of games.
EK-Matrix7 Standard
EK-Matrix7 standardizes the product’s dimensions, including port position and spacing, making liquid cooling loop assembly easier and more intuitive. All Vector² products feature full EK-Matrix7 compliance in every axis for easy integration and perfect alignment with other EK-Matrix7 products. This perfect alignment of ports in both horizontal and vertical positions means less time spent planning the loop and bending tubes, with the end result being an epic build.
Graphics EngineRX7900XTX 24G-W/OC
Video Memory24GB GDDR6
Stream Processor6144 Units
Engine Clock (OC)up to 2455 MHz (Game); up to 2615 MHz (Boost)
Engine Clock (Unleash)up to 2510 MHz (Game); up to 2680 MHz (Boost)
Memory Clock20.0 Gbps
Memory Interface384-bit
DirectX® Support12
Bus StandardPCIE 4.0
Standard Display Connectors1 x HDMI 2.1,3 x DisplayPort 2.1 (only 2x simultaneous DP2.1 connections can be supported)
-John Nester (Blaylock)
About John Nester 378 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Discussion
Leave a Reply
