Table of Contents
EKWB recently announced the launch of its latest All-In-One CPU cooler, the EK-AIO 280 D-RGB. Powered by an integrated SPC style pump, it features a 27 mm thick 280 mm long radiator and a pair of 140 mm D-RGB Vardar S fans. The water block utilizes a copper cold plate with dense fins and a frosted acrylic top with RGBs underneath for light dispersion. Pre-ordering is available now with shipping expected in the second half of February. The retail price is set at $135 with free shipping to the United States. Here is EK’s press release.
EK INTRODUCES EK-AIO 280 D-RGB, ITS LATEST ALL-IN-ONE SOLUTION
January 21, 2021
EK®, the leading computer cooling solutions provider, is expanding its All-In-One product line with the highly anticipated EK-AIO 280 D-RGB. Following the success of EK-AIO D-RGB that comes in three different sizes, the latest EK-AIO 280 D-RGB was first introduced at the EK EXPO Reloaded Livestream event. It is meant to cater to customers who eagerly awaited the 280mm radiator version combined with two 140mm D-RGB Vardar S fans. This All-In-One solution is simple to use and easy to install with top-of-the-class cooling performance and fully customizable D-RGB lighting. The EK-AIO is an ideal solution for anyone who wants all the benefits of liquid cooling without all the maintenance it can bring.EK-AIO 280 D-RGB
The dual-fan EK-AIO with a 280mm radiator is the perfect all-rounder for standard case sizes. The radiator surface is big enough to combat any mainstream CPU on the market and even has enough headroom for overclocking. An AIO with cooling capacities like this can either provide a super-silent PC setup or help harness the extra performance of an overclocked processor.
The robust SPC style pump ensures sufficient coolant flow through a dense copper fin structure, delivering optimal performance for its class of AIO products currently on the market. A sizeable pump housing indicates the quality of the pump that promises smooth and quiet operation and durability. The frosted cover of the pump unit acts as a perfect light disperser for the integrated addressable D-RGB LEDs.
A high-grade 27mm thick aluminum radiator with a density of 19 fins per inch is ensuring efficient cooling. The thickness, or better yet, slimness of the radiator makes sure that EK-AIO is compatible with the majority of popular cases. The stylish black radiator, while being slim, is also being efficiently utilized since the radiator core has almost the same thickness as the outer body of the radiator.
EK-Vardar S 140ER Fans
The included addressable Vardar D-RGB fans are high-static pressure cooling fans, designed and built primarily for radiator use with liquid cooling systems. The perfectly balanced milky colored 7-blade rotor design is optimized for light dispersion and high-pressure operation while maintaining the low noise profile throughout the whole operation range of the fan. Compared to the 120mm fans, EK-Vardar S 140ER outputs the same performance at lower RPMs, which means it can offer an overall quieter experience.
Availability and Pricing
The EK-AIO 280 D-RGB is designed in Slovenia and made in China and is available for pre-order through the EK Webshop. The estimated shipping date of EK-AIO is scheduled for the second half of February 2021. The good news for US customers is that until the EK-AIO 280 D-RGB arrives at EK’s Amazon Store, MSRP is $134.99 there will be no shipping cost for the US!
No replies yet
Loading new replies...
