EKWB
Table of Contents
Late last week, EKWB launched the EK-Quantum Delta2 TEC CPU cooler for Intel’s latest LGA1700 socket CPUs. Designed for maximum single-core overclocking and better multi-core overclocking than water cooling alone, the EK Quantum Delta2 TEC relies on the Peltier effect to reduce temperatures below ambient. The cost for EK’s latest TEC cooler is quite high, so this is not a cooling solution for enthusiasts on a tight budget. EK is accepting pre-orders now with an expected delivery date later this month. How much is it you ask? Ek expects the MSRP to be around $540 US dollars.
For further details about the technology and how it works, please read EK’s press release below.
EK Rolls Out New Delta² TEC for LGA 1700 and Intel 12th Gen Core CPUs
EK®, the leading computer cooling solutions provider, releases the latest generation of its TEC solution – the EK-Quantum Delta² TEC – a CPU water block for extreme cooling. In collaboration with Intel®, EK has developed a next-generation water block for enthusiasts seeking consistent peak performance and ultimate overclocking of the unlocked 12th Gen Intel Core™ desktop processors.
EK-Quantum Delta2 TEC Cooler
This water block is based on Peltier (ThermoElectricCooler) technology and can transport heat using the Peltier effect. Inside the TEC plate, the Peltier effect produces a temperature difference between the two sides by flowing a current through it. This means the cold plate, which is in contact with the CPU, can be lowered to sub-ambient temperatures while the liquid cooling loop cools the hot side of the TEC.
The EK-Quantum Delta² TEC brings further improvements to the original EK-Quantum Delta TEC design. Instead of the one original TEC plate, the new generation has four TEC plates. These are soldered to the bottom of the water block that goes over the CPU, improving the contact and cooling the block and eventually the CPU. Another improvement is that TEC plates are no longer made of Aluminum Oxide but Aluminum Nitride (AlN). Aluminum Nitride (AlN) ceramic plates are cutting-edge thermoelectric plates that significantly improve power efficiency, especially at higher power levels.
The water block features the signature Quantum design, also seen on Velocity² products, along with the controller unit. The controller is now a separate element, intended to be mounted on a nearby 120mm fan mounting inside the case. As such, it no longer impairs the visual appearance of the water block, which was the case with previous generations of EK TEC products. The control unit can now connect and control the pump and fans of the loop used to cool the TEC plate, making it even more user-friendly.
And this is not where improvements stop. Further updates were made to the insulation that prevents condensation, now with a dense high precision-made rubber frame instead of foam. The water block uses built-in mounting screws already equipped with retention springs. It also has two additional thermal sensors – one on the hot and one on the cold side of the Peltier element – for precise monitoring and control of the TEC plates.
It is exclusively powered by Intel Cryo Cooling Technology, a unique combination of hardware, software, and firmware designed to help unleash extraordinary performance for gamers and those hunting for the highest boost frequencies.
This unique cooler is made for maximum performance and frequencies during heavy loads on a single core or lighter loads across more cores. It is not intended for torture and stress test software that applies heavy synthetic load across all cores, like Prime95.
The EK-Quantum Delta² TEC is built using a purpose-designed large-surface flow-through cooling engine with the Intel Cryo Cooling Technology, bridging aesthetic uniformity and near-silent operation with technological advancements in thermal solutions. The cooler presents an exceptional application of CPU cooling with sub-ambient temperatures by utilizing the Thermoelectric Cooler (TEC) plate while continuously monitoring and adjusting temperatures dynamically, achieving an ideal operating environment for sustained gaming performance.
Liquid coolers are unable to reach temperatures below ambient (room) temperature, while EK-Quantum Delta² TEC uses cutting-edge technology – actively cooling the CPU to sub-ambient temperatures while extracting and dissipating the heat generated from the TEC plate through the traditional liquid cooling loop.
The EK-Quantum Delta² TEC utilizes an innovative two-pronged approach to mitigate condensation, a byproduct that has plagued previous attempts of sub-ambient cooling. The cooler features a compact integrated insulation rubber shroud that isolates all exposed cold surfaces from the environmental conditions inside the PC, while Intel Cryo Cooling Technology continuously monitors the TEC and ambient temperature to adapt itself to those conditions and prevent condensation generated by the cooling process. An additional sensor is located inside the control unit to monitor the humidity inside the chassis and avoid the dew point.
Availability and Pricing
TheEK-QuantumDelta² TEC is available for pre-order through the EK Webshopand partner reseller network. This product is estimated to ship out in mid-August 2022. The table below shows the manufacturer’s suggested retail price (MSRP), VAT included.
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Recently we had a chance to look at a couple of EK products. I reviewed their 295×2 waterblock,and just a few days ago Lvcoyote reviewed their Supremacy EVO CPU waterblock. Both of those products performed quite well during their reviews. Today, we have a complete custom kit from EK, which they call the EK-KIT X240. This kit comes with a 2×120 mm double thick radiator, their DDC 3.2 PWM Elite Edition pump, the Supremacy Clean CSQ waterblock, and all the parts needed to complete a full custom loop. Today, we will put it through its paces and see how it fares!
MSI and EKWB have joined forces once again announcing the second generation MSI MPG CARBON Z590 EK X motherboard (We first reported the Z490 version back in June). The new board, an MPG Carbon Z590) is based on the Z590 chipset supporting PCIe 4.0 natively (with a Rocket Lake based CPU), Wi-Fi 6E, and Bluetooth 5.2. Pricing is listed as $499 and will be available for pre-order on 2/22 from the EK Webshop and MSI’s worldwide retailer network. Below are is the press release showing off several of its features.
This is a guide for people who aren’t shy with a soldiering iron to really unleash the Kepler-based GTX 680. It is not necessarily for the faint of heart!
Phase cooling takes a much larger set-up and is very loud. But I agree the price makes this thing completely unattractive. Don't get me wrong, I'd love to get my hand on one to play with, but I would never buy it.
Yes, it should draw less than 150W. Another concern I have is this product is socket LGA1700 specific meaning it will only be usable for a few upgrades, unlike liquid cooling components. At least LGA1700 is a new socket and should be around for a few generations. It is also possible that EK will (and certainly should) make adaptors plates for future sockets.
Most blocks like this are only going to be good for a specific socket anyway. Unlike AIOs and other CPU blocks that (in many cases) just needs a backplate for compatibility, the mounting posts on the block are static so if the holes change on the board, my non-mechanical-engineer mind doesn't know of a way to make it fit. Many CPU blocks and AIOs are flexible in that manner and why a different backplate and perhaps different height studs allow for even more compatibility.
But yeah, you get this, you're all in on LGA1700, eh!? The good news is that LGA1700 has a couple of generations left.
It says 210W max load so that's a fairly beefy TEC. They spec it only for heavy single or lightly threaded loads, so I see limited utility in it outside of maybe some benching.
At least with today's PSUs powering the TEC isn't an issue. Nice plug and play kit.
Loading new replies...
1
1
1
1
1
1
