Enermax Launches Value Oriented MarbleShell Series Cases
30 July 2020 – Enermax launched the MarbleShell series chassis geared for the budget-minded builders. The MS30 and MS20 are both stylish cases that feature ARGB fans and front lighting. The MS30 is a mid-tower case that can fit ATX and smaller motherboards while the MS20 is capable of micro-ATX and smaller. Here is what Enermax has to say along with the case specs.
ENERMAX launches a value-segment addressable RGB computer case-MarbleShell series
Taoyuan, Taiwan – July 30, 2020– ENERMAX, a leading designer and manufacturer of high-performance PC hardware products, launches an addressable RGB computer case featuring modern front panel design, in which the dynamic lighting effects of the pre-installed addressable RGB intake fans will reflect from the gaps between the marble-styled front panel and deliver a stylish look. The MarbleShell series is designed with a tempered glass side panel and a multi-functional tunnel at the bottom which ensures a neat and tidy appearance inside the case. The series includes mini-tower and mid-tower versions; each version also has black and white colors available.
2 Ways to Control Addressable RGB Lighting EffectsMarbleShell series offers 2 ways of addressable RGB lighting control, one is connecting with addressable RGB-enabled motherboards which users can control the lighting effects by the motherboards’ software, the other is to select the pre-set 13 lighting effects by the top I/O port. This series further provides an integrated hub to keep 6 addressable RGB devices’ lighting in sync.
System Configuration
MarbleShell MS 20 is a mini-tower case and MarbleShell MS30 is a mid-tower case. Below is the system configuration comparison table:
MarbleShell MS20MarbleShell MS30
Motherboard SupportMicro-ATX, Mini-ITXATX, Micro-ATX, Mini-ITX
Dimensons (D x W x H)417mm x 210mm x 400mm407 x 215 x 460mm
Fans Included
2*120mm addressable RGB fans
1*120mm Non-LED fan
3*120mm addressable RGB fans
1* 120mm Non-LED fan
Fans Support
Front: 140mm*2 fans / 120mm*3 fans
Top: 140mm*2 fans / 120mm*2 fans
Rear: 120mm*1 fan
Rear: 120mm*1 fan
Radiator Support
Front: 280mm/ 240mm radiator
Rear: 120mm radiaotr
Front: 360mm/ 280mm / 240mm radiator
Top: 240mm radiator
Rear: 140mm / 120mm radiaotr
Maximum GPU Card Length368mm357mm
Maximum CPU Cooler Height164mm175mm
Expansion Slots47
MarbleShell series has pre-installed addressable RGB fans in the front and one case fan at the rear, which automatically generates optimized airflow through the computer case. Its modern and stylish front panel design, combining with the dynamic lighting effects through addressable RGB components, MarbleShell series is your perfect selection to decorate your room and be your gaming rig.
Enermax MarbleShell MS30
Enermax MarbleShell MS20
Visit the product page:
MarbleShell MS20- https://www.enermax.com/en/products/marbleshell-m-ms20
MarbleShell MS30- https://www.enermax.com/en/products/marbleshell-ms30
About ENERMAX
ENERMAX Technology Corporation is a world-renowned PC Power Supply Unit manufacturer and maker of peripherals such as chassis, coolers, fans, and storage solutions, all with excellent quality, having won recognition from consumers around the world. Our farsighted R&D capability is our key strength and we stick to our spirit of “Technical Innovation” and “Quality First” to create products which transcend international standards. Visit us at www.enermax.com
©2020 ENERMAX Technology Corporation. All rights reserved. Omissions and printing errors excepted. Some trademarks may be claimed as the property of others.
-John Nester (Blaylock)
About John Nester 399 Articles
John started writing and reviewing PC components for Overclockers.com in 2015, but his passion for PCs dates all the way back to the early 1980s. His first personal computer was a Commodore 64 with a cassette drive. As a dedicated member of the news team, he focuses his articles on new product releases and software updates. He reviews a wide variety of PC components including chassis, storage drives, keyboards, and more. John works in technology as a C.A.D. designer for a major automotive manufacturer. His other passions in life include motorcycles, hunting, guns, and football.
Loading new replies...
Avatar of Overclockers.com
3,185 messages 156 likes
30 July 2020 - Enermax launched the MarbleShell series chassis geared for the budget-minded builders. The MS30 and MS20 are both stylish cases that feature ARGB fans and front lighting. The MS30 is a mid-tower case that can fit ATX and smaller motherboards while the MS20 is capable of micro-ATX and smaller.
Click here to view the article.
Reply Like
