Results 1 to 5 of 5
Thread: Power strip
  1. #1
    Power strip
    Hey guys I just wanted some help I think I may of damaged my computer.
    I have a power cord connected to my PSU to my computer. I split tiny drops of water onto the plug and it started buzzing, I was freaking out for like 5 seconds until i shut off my computer.
    Took the cord out and one of the 3 pins had a tiny black burnt area.
    I booted my computer from another power cord and it booted fine but my CPU was not 4.4GHz anymore but instead went down to 3.4GHz (At the boot menu it did say something about let everything go default i think?)
    Not a problem, so i went into bios and it was at 4.4GHz settings so i just save and exit and now it's back to 4.4GHz
    My computer then suddenly restarted when i loaded Speedfan (I'm worried)
    now i'm just booting it up and running Prime95 and no problems so far
    My question is does anyone have any methods to check if any of my computer parts are damaged? I have no clue how to check so i'm just running Prime95 to see if anything happens to my computer
    CPU: AMD Fx-4100 @ 4.4 Ghz
    CPU Cooler: CoolerMaster Hyper 212+
    Mobo: ASRock 970 Extreme3
    Ram: G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
    GPU: SAPPHIRE Radeon HD 6850 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP
    HDD: WD Caviar Blue 250gb 7200 SATA 3.0Gb/s 3.5"
    PSU: 500w Cooler Master eXtreme Power Plus RS500-PCARD3-US ATX12v v2.3
    Case: COOLER MASTER HAF 912 RC-912-KKN1 Black SECC/ ABS Plastic ATX Mid Tower Computer Case
    OS: Windows 7 Ultimate 64bit
  2. #2
    Senior Member
    Bobnova's Avatar
    Join Date
    May 2009
    Author Profile Benching Profile Folding Profile Heatware Profile Rosetta Profile
    If nothing went BAM it should all be fine.
    Stability testing is step1.
    Or a multimeter/paperclip PSU test per the link in my sig.
    "Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe." -- Einstein (maybe)
    How to check your PSU with a multimeter.
    17bXw5t51rEBXGavJFMJsC8g7HQgThUGc7
  3. #3
    thank you for the fast reply
    I don't have the equipment for the multimeter test
    as for Stability testing, how would i go about that?
  4. #4
    Member Conumdrum's Avatar
    10 Year Badge
    Join Date
    Sep 2007
    Las Vegas
    Author Profile
    Prime 95 Furmark etc tests. Make sure it passes tests. maybe memtest too.
    I want my old title back.
    Old beast is torn down.
    Will update later.
    900 watt (1500VA) UPS
    27" ASUS VG 3D/Nvidia V2 3D glasses and 24" Acer H243H
  5. #5
    So have you thought of adding GFCI (Ground Fault Circuit Interrupter) protection to your wall outlets. It might not have stopped the buzzing or burn mark, but it would have almost guaranteed that the situation couldn't have possibly become deadly. One wired-in GFCI can protect all the downstream wall outlets. There are also plug-in GFCIs that will protect only what's plugged into it.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
