- Mar 14, 2013
- Massachusetts
Hey all,
I'd like to heat shrink the wires on my EK Dual D5 PWM Pumps, and was wondering if folks knew of any solid recommendations on heat shrink tubing or a kit. The cables are simply just a 4pin molex for power and a 4 pin fan header for PWM. The tubing fitting over the Molex would be the bigger item.
Don't need anything fancy, just something to organize and clean up the wires.
Thanks!
Matt
Thanks!
Matt
