- Jul 28, 2002
- perth.wa.au
the highest i got it to was 145fsb. (it would boot at 150, but crashed into windows)
the ram was set to Host CLK. (PC133 CAS3 ram @145 CAS3 )
the voltage was set to 1.70v
other than that, there wasn't anything really out of the ordinary.
your ability to hit 160fsb will depend on your PCI/AGP cards.
with the dividers this board has your PCI/AGP will be at 40/80mhz.
that's pretty high for some cards. i'm sure most decent card should be able to handle it.
it will also depend on your ram.
i'm guessing your generic stuff will be just about maxed out at 153fsb. (unless it is PC150, but is there such a thing as generic PC150?)
if you set the ram to run at HCLK-33 and the fsb to 160, the ram will be run at 127mhz.
it won't be as good as running it at 153mhz, but if you run it at CAS2 it'll still perform ok.
