1/2" over 5/8" tube
BigFloppyLlama
The heatercore I bought off of e-bay uses 5/8" inlets and outlets. I have no access to a welder so I'm looking for other options. Its clearflex 60 so it has some give. I was thinking about dremeling off any extra length I don't need, and then bending in the cut to prevent any rough edges from cutting the tube. Then soaking the tubing in hot water and clamping it on. Good idea, bad idea?
samcim69
uk
i have pushed my clearflex 60 1/2" over a 5/8 barb usin warm water quite easy hope this helps :D
