I just got my 1.33 Ghz. It is running at 55-57C idle and hit 64C today during some load (I shut down then
). This is with the case open too.
I attached the heatsink three times just to make sure its
correct.
If I read correctly on AMD's "thermal solution page" socket A >1100Mhz can hit temp of 95C.... Is this correct?
If so I should not be too worried about the temp?
What temps are other 1.33 GHz hittign out there? Please tell me..
I have a MSI K7T Turbo mobo and use a globalwin FOP32-1 HSF with arctic silver (small core).
Would taisol 742092 do a better job? or a coolermaster ep5-6i11 (6i51?)
foxconn PK0451? (where can one buy those anyway? )
I do not want a really loud fan.
Any input/suggestions would be appreciated.
correct.
