1/4 divisor, 1/5 divisor?
skid
IL
How do you tell the divisor of your mobo?
Mine is a KT-266 chipset. Am I correct in assuming it has a 1/4 divisor?
Tipycol
You're right that it has the 4th divider. If you have a KT333 or KT400, then you'd have a 5th divider. I am pretty sure you can check your divider in the bios, and find out what your max is there.
ronin1967
Highland Park, NJ
not true with every motherboard, my EPoX for example, when I change the FSB in BIOS it shows the PCI and AGP frequencies reflected by the change, and when I get to 166FSB it even drops to the lower dividers so I can run at defaults(33 PCI 66 AGP)
Garfield
New Jersey
get sisoft sandra and it tells you the divider and what speed you pci/agp are running at. it pretty much tells you everything you need to know... :D
