Would a waterblock designed to work with 1/4" tubing be able to work well with 3/8" tubing, radiator, and Eheim 1048 pump on a pentium 4?
I am asking this because I will probably be buying the Swiftech which uses 3/8" tubing but if I can use my 3/8" tubing setup with a waterblock designed for 1/4" tubing then I will be getting the new Koolance CPU-200 waterblock. The new Koolance cpu waterblock is extremely easy to mount on a socket, weights to almost nothing, and has a copper base coated with silver!
Please answer this soon so I can order my stuff ... Thanks
