- Apr 9, 2002
- NH
I have an Asrock 939SLI32-ESATA2 motherboard. The board is an AMI
Bios revision v. 02.58.
I have 2 sticks of Crucial Micron DDR 400 512mb memory installed.
Model: CT6464Z40B.16T Cas level 3. Micron part number -
MT16VDDT6464AG-40BC4 PC3200U-30331-B1.
I also have one stick of Ultra 30215 512mb DDR ram.
I am running Windows XP with service pack 2.
The board has 4 memory banks, two of which are populated with the two
sticks of 512mb ddr 400 ram.
The problem is this. When I install the Ultra 30215 DDR ram, the bios recognizes that I now have 1536mb of RAM.
However, when I exit the bios and the computer starts its' memory test
it is only showing 1024 MB available. When I go into windows it also
only shows 1024mb. Basically, I am 512mb short when I use the Ultra ram.
I contacted Asrock support and they told me that the micron memory and ultra memory are incompatible with each other. That is why I am only seeing the one gig.
I contacted Ultra memory. They had me run CPUZ. Under the memory section of CPUZ, it shows that I have 1536mb of RAM.
The rep told me that based upon what CPUZ is reporting, windows is using all this RAM for programs . How can I tell if he is correct?
