If you check some other threads, I have basically been w/o a pc for over 2 weeks waiting for abit tech support to help with a boot block error after upgrading to the 38 bios. But my question is this.
I know the 1.8a @ 2.4 using the 4x memory setting is best. However if it will only post @ 2.4ghz with the memory setting at the 3x mode, making it effectively at 400mhz which is the default spec, taking memory bandwith into account, is it better to run the 1.8a @ 2.2ghz with the memory overclocked, or running the 1.8a @ 2.4ghz with the memory at default? as I have no pc right now. I was able to boot into both of the above mentioned speeds, does anyone have any benchmarks or something they can point me to , to check on this? i'm gonna assume @ 2.2 with the memory overclocked is gonna give a better boost all around, but any ideas/links would be helpful, thanks.
