Please for advice they all cost around £100 , they all Full HD ,
I really want Philips one but its a best choise ?
Philips Brilliance C-line 226C2SB LCD TFT 21.5" Full HD Monitor
Quick Look
Philips Brilliance C-line 226C2SB LCD TFT 21.5".. | Ebuyer.com
BenQ G2222HDL 21.5-inch Widescreen LED Back-Light Monitor
BenQ G2222HDL 21.5-inch Widescreen LED Back-Light Monitor (Full-HD, DVI-D, Glossy Black, 5ms, Vista Premium): Amazon.co.uk: Computers & Accessories
Hanns G HL225DBB - 22" Widescreen LED LCD Monitor
http://www.play.com/PC/PCs/4-/18658510/Hanns-G-HL225DBB-22-inch-Widescreen-LED-LCD-Monitor/Product.html?searchtype=PCSH&searchsource=0&searchstring=Hanns+G&urlrefer=search&strefer=PCSH&searchfilters=s{Hanns+G}%2bc{420}%2b
What You think guys witch is best , just 2 of them have 2ms response
Is Philips good choise? or You would go for other one and why ?
Quick Look
cost : £108
- Product Description: Philips Brilliance C-line 226C2SB - LCD display - TFT - 21.5"
- Device Type: LCD display / TFT active matrix
- Colour: Glossy black
- Dimensions (WxDxH): 51.5 cm x 19.8 cm x 39.9 cm - with stand
- Weight: 3.3 kg
- Diagonal Size: 21.5" - widescreen
- Dot Pitch / Pixel Pitch: 0.248 mm
- Max Resolution: 1920 x 1080 / 60 Hz
- Video Format: 1080p (FullHD)
- Display Positions Adjustments: Tilt
- Colour Support: 16.7 million colours
- Image Aspect Ratio: 16:9
- Response Time: 2 ms
- Image Brightness: 250 cd/m2
- Image Contrast Ratio: 800000:1 (dynamic)
- Digital Video Standard: Digital Visual Interface (DVI)
- Signal Input: DVI-D, VGA
- Compliant Standards: FCC Class B certified, CE, UL, BSMI, GOST, cUL, FCC, DDC/CI, RoHS, TCO Displays 5.0
- Power Consumption Operational: 23 Watt
- Environmental Standards: ENERGY STAR Qualified
Cost: £108
- Product Description: BenQ G2222HDL - LCD display - TFT - 21.5"
- Device Type: LCD display / TFT active matrix - LED backlight
- Dimensions (WxDxH): 51 cm x 17.5 cm x 39.3 cm
- Weight: 3.8 kg
- Response Time: 5 ms
- Image Contrast Ratio: 1000:1 / 5000000:1 (dynamic)
Cost: £99Display size 54,6 cm / 21.5" WIDE
* Panel Type TN TFT LCD / LED backlight
* Brightness 250 cd/m² (typ.)
* Contrast (typ.) 1000:1
* Pixel pitch 0,248(H) x 0,248(V) mm
* Resolution (H x V) 1920 x 1080 (16:9)
* Response time 5 ms (typ.)
* View angles (CR>10) H/V 170°/160°
* Display colors 16,7 Mio colors
* Display Surface Anti-Glare
* Input 1 VGA
* Input 2 DVI-D (HDCP)
* Supply AC 100~240V, 50~60Hz internal
* Consumption 28 W
* Operation Temp/Hum 5 ~ 35°C 20% ~ 85%
* Dimension (W*D*H) 515 x 375 x 45 mm
* Net weight 3,1 kg
* Tilt -5°~ 15°
* Kensington Lock ¿
* VESA mounting VESA Standard, 100mm
* On screen display EN,DE,FR,ES,IT,PT,NL,RU,SC,TC,JS,KR
* Safety CE, CB, GOST, 3C
* Emission TCO 5
* Power saving Energy Star 5.0
* Extras 1 Windows 7 compliant
* incl Accessory Cable (Power, VGA), Quick-Start-Guide, Usermanual (CD)
