1070 vs 1060 vs RX 480 budget / performance and 4k gaming
shmu321
Hi I am choosing between the 1070, 1060, and RX 480. the 1060 or 480 would allow me to allocate much more moneyi nto the other parts but I do game alot and would like to be ableto play the newer games (GoW 4, Doom, etc) on the higher or highest settings. I also have a 4k monitor as well as a 1920x1200 to use the 4k for gaming would thatl limit me to only the 1070? Between the 1060 and RX 480 what would be a better option? Thank you any help / suggestions would be much appreciated. Thanks, Sam.
Tír na nÓg
4K gaming highest settings, you'd need a 1080, or a couple of 480's.
None of the options you mentioned will cut it.
Mjolnir
Sydney, Australia
The 1070 will be the 'best' of your options, but it will not keep up at 4k realistically without turning things down. A single 1080 struggles as is, and 4k really requires dual cards for 100% always smooth gameplay maxed out.
S
shmu321
So since two RX 480s would be less expensive then the 1070 (the 1080 is a little far out of my budget)would this be the best option?
Saul Goodman
Adelaide
You'll need a 1080 at least for 4K.
The RX 480 is the better option than the 1060, unless trying to get a really quiet/low power draw card for a mini form factor build or something.
Could buy a cheap 480 and sell it, to then purchase Vega/1080ti?
8GB 480 should have decent resale value as you can crossfire and has 8GB vram, unlike the 1060 that can't sli (lol) and 6GB vram.
JrClocker
AKA: JrMiyagi
A single Titan X Pascal does 4 K...but that's probably out of your budget range.
