- Dec 25, 2004
I've got a system that is eventually going to have 4 1080 Ti cards in it.
Currently it has 1 1080 Ti FE Nvidia card, and I'll have an EVGA FE version in about 2 weeks.
I'm going to pull the trigger on another card today.
I'm going to be using riser cables to help manage air-flow. Either 9cm or 20cm cables. Probably 20cm cables with 2 cards on cables and 2 directly in the motherboard.
Withe the FE cards, the riser cables won't be in the direct path of a intake fan. I'm going to have 2 FE cards for sure.
Would I be better off with the riser cable cards being multi-fan cards?
Any suggestions on the best multi-fan cards under $725 if I go that way?
Sorry, still thinking this out.
Edit: open air benching station.
