- Apr 10, 2010
System
i7 7800x factory speed
Tuf x99 mark 2
1080TI GPU
650 watt thermal intake psu
my system ran perfectly fine with my 1070 I bought a 1080TI Used * ya ya i bought it used ** installed it and pc runs fine but under gaming it shut down twice on my temps only hit 77C
my psu has a spare slot 8 PIN on it not being used if i ran a pci cable 8pin from that to the 4 pin on my gpu would that free up some power for it to run better ?? I read online some people did that and it worked... if thats my problem
any ideas ?
I just used pcpartpicker to see if there was problems
https://pcpartpicker.com/list/#problems
it says
1 additional EPS power connector is needed.
Tuf x99 mark 2
1080TI GPU
any ideas ?
it says
