Hi all
I'm researching for my first new PC build in a decade, having saved for a long time. I run a Hackintosh, so I've decided to limit myself to Intel CPUs, as this is better supported when running macOS. My prime usage will be video editing and development, plus the occasional game (for which I'll dual-boot into Windows 10.)
I've looking at the following HW:
CPU: Intel 10980XE Extreme
MB: Gigabyte X299X Designare 10G (I want Thunderbolt 3 and 10GB Ethernet, and I know this MB works well in a Hackintosh)
RAM: 128GB (4 x 32GB) DDR4-3600 or 3733 (eg Corsair Vengeance Pro CAS 17-19-19-39)
GPU: my existing AMD Vega 64 8GB to start with, then hopefully the new 16GB AMD Big Navi RX 6000 card when it's available (I am limited to AMD GPUs due to running macOS)
NVMe drive: 1 or 2 TB
Case, PSU, cooling: To be decided
I would like to OC the 10980XE if I'm able to, and need to decide on what cooling and power to get. I don't want to go full custom loop water yet as I have no experience of it. I'm thinking I'll start with a 360mm AIO radiator, and maybe upgrade to a full custom water setup sometime in the future.
For the radiator I'm quite interested in the Coolermaster MasterLiquid ML360R, as it was Tom's Hardware's top recommended 360mm radiator, and it's quite affordable.
My first question is: what sort of OC am I likely to get on a 10980XE with a 360mm radiator like that? I've heard that all-core OCs are quite challenging on this CPU, so I'm not expecting big number. But it'd be great to get a bit of a boost if possible.
Or, should I consider a different 360mm AIO cooler?
Secondly: what size PSU should I be looking at for this system? Is 1000 or 1100W enough? There seems to be a big price jump to 1200W or 1300W so I'm hoping 1K will be enough for a moderately-OC'd CPU + single GPU?
Thanks very much in advance for any help and advice!
