- Oct 27, 2002
First of all, i would like to say hello, this being my first post and all. I just discovered this forum a few days ago, and i have already found a ton of useful info which helped me to complete my 2nd custom pc. I just finished building my new p4 1.8(not overclocked, yet
) which is housed in a chieftec matrix full tower server case(blue). Before making the swap, my cpu temp would idle at approx 52C(60 at full load) and the case temp usually hovered around 33C. However, i discovered that after i swapped my comp into the new case the system(case) temp rose to about 38C and the CPU climbed to 54C at idle
I started to believe that my temp sensors were whacked out, since this case had more fans and was supposed to provide even better airflow characteristics(my last case was a POS!) After about 2 hours of tinkering, i came to the conclusion that this was normal and i decided to live with, UNTIL i opened my office room window. Literally, 10 minutes after opening the window, i noticed the cpu and case temp start to drop. Finally after approx 1-1/2 hours, the case temp dropped to 28C and the CPU to almost 42C. !!!
As you might of guessed, i was amazed. i could not believe that opening the window would cause the temp to drop so significantly. Anyways, just thought u guys might benefit from this if you live in a cold climate( its winter in CO right now, so the average temp is about 40-50.
ps sorry for the long post, i just needed to tell some1. (most of my friends think ive gone absolutely nuts, but oh well
ill try to post some pics of my comp and office, but i need to find a site from which to host my pics
Happy modding and good night!!!
