10GB Fiber Home Network upgrade, want help
trekky
My switch is showing major signs of death, ports have stopped working and gone into error mode, etc.
so i am starting to look for a new (to me) one. Currently i have a Cisco 2970g which is 24 ports at 1gb
I can not afford a full 10gb switch so i have to stay with 1gb for the time. however i want to add 10gb to my server which is in the same rack as my network devices.
i am looking at a CISCO WS-C3560E-48TD-S which has two 10 GB up link expansion ports on ebay for about $120
( i know this is out of stock but i can find others)
so i need to add fiber modules (because 10gb copper modules are too pricey still)
so i was thinking these, but dont know if they will work
(EDIT)
I Talked to a person at work who does fiber and he said you sould get LRM or SC fiber
PCIe Card
Cable
SC
SFP
X2 Module for switch
LRM (better)
SFP
thx
JrClocker
AKA: JrMiyagi
Why do you want 10 G Ethernet?
Also - the "uplink" ports are for switch-to-switch so that you can have a high speed trunk between switches.
t1nm4n
Texas
Same reason I've been thinking abut upgrading to stupid overkill network speeds at home, because we can, but that's just a guess.
trekky
trekky
So True!!, If i am buying a switch i want to feel like i got an upgrade!
wagex
Chapstick Eating Premium Member
i know what you mean, i thought about the same thing, much cheaper to use a 1gb switch and use multiple trunked ports in conjunction with teamed nic connections on the server.
gangaskan
Lorain, ohio
i wonder if you can do those copper sfp's with the MELLANOX card
the twinax 10gig cisco ones. you should be able to get those for cheap.... unless your switch does not support sfp+ then you're going to have to go with fiber and transceivers.
