redkaliber
- Jan 2, 2013
Sup overclockers. I'm new to these forums and I'd like to throw a couple numbers and letters at you all. The reason I'm here is because the past three days I have been viewing all kinds of threads and articles related to overclocking. But anyway heres my rig info :
CPU - AMD 1100T BE x6 / Heatsink - Corsair h80i / Memory - (2x) Corsair 4Gb 1333 / GPU -(2x) AMD HD6870 Crossfire / Storage - Toshiba 2Tb HDD sata 3g 64Mb cache / Mobo - ASUS Sabertooth 990fx / PSU - Corsair 800watts / Case - Corsair 600T
So I guess I got a slightly higher midrange PC. I just recently bought the H80i and have been trying to increase my overclock from 3.85ghz on a CM hyper (the big *** one with two fans, maybe 542) to a 4.3ghz on the h80i. Thats the goal. I had some trouble at first. Mainly because I was doing it the inpatient way of just raising it really high and changing a bunch of settings in the bios at once. So, I took a break and started reading. Got back to it with some better knowledge. Overclocked it to 4.12ghz with a FSB of 249.7~9mhz.
I did it in increments. Started at 3.8ghz FSB - 230mhz. Ram at 3:8 and voltage at 1.45v. I would increase the FSB by 5mhz and prime 95 it for 20-30 min. while watching my temps in hwmonitor. I got to 4.05ghz fsb - 245mhz on 1.45v. after I raised it to 250mhz fsb it didnt even get into windows. I didnt want to give up so I started raising the voltage. I raised the Dram voltage to 1.55 from 1.5 and threw increments at the cpu voltage. I also turned LLC to ultra high(4). I was priming and it was BSODing until I got it to 1.5v. LLC brought it up to 1.512 during prime and it ran stable for an hour. WHAT WHAT! Told yea I get that shiet. haha.
Anyway, Now I just gotta let the thermal compound burn in cuz when it was priming it went up to 61c on cpu temp, 47c on cores. After burn in it might drop 4 or 5c and I will try getting it higher. Also my memory is at 666.7mhz so 1333. the NB and HTL are at 2000. I kinda wanna try raising the NB frequency. Other than that I saw a review of crossfired HIS 7850's at tweaktown so thats my next upgrade. Or maybe I should get an SSD first. I dont hear anything about them being unreliable anymore, plus the prices are low enough now.
What you guys think?
