- Mar 27, 2001
- Cyprus - Europe
I was wondering, what is the typical difference in temperature at the very top of a case compared to its very low part? I have an Antec 1200 full tower case, my idle system temps being 27C and system full load temps being 31. I have thought of removing the hard drives rack and mount my 2 hdds in the upper cdroms rack and mount the heatercore verically at the front of the case. Another thought i had was mounting it horizontally either on the very top of the case or the very bottom, since my pump is submersed into a cuboid reservoir. Another issue, i have mounted 2 120mm fans in series on the front side of the heatercore, so will i have to cut off my case so that the air pushed through the fins by the fans gets out? since the heatercore in all 3 cases will be in contact with the case, there is no other way for the blown air to escape. I dont want to slaughter me case
Please advice, thanks
