120 mm panaflo
overdoze
Texas
Would this work well with black ICE extreme. I plan on cooling dual processor. The heat is roughly 150W. The fan only move 69cfm. Would that be enough or should I go with higher rpm fan. I'm pretty sensitive with noise however.
Hoot
Inactive Moderator
Twin Cities
Though I don't agree with you on your choice of radiator for a dually, let me recommend that whatever radiator you wind up going with put a pair of these on it in a push-pull sandwich.
They are quiet and together they are very effective.
Hoot
overdoze
overdoze
Texas
Thanks Hoot. I imagine the push pull will work well as well.
The radiator choice (don't agree?) Is it too big or too small or too expensive? please spell it out.
Über~PhLuBB
Jedi Knight Senior
Portland, OR
Hoot said:
No, No, Yes!
Check out this heater core/radiator. Excellent performer, ask anyone using it and only ~$25.00
Hoot
That's all fine and good, what that model/year of car/truck is that from, so we'll know what to look for on Ebay? =)
Hoot
Inactive Moderator
Twin Cities
I believe it is for a 1987 Chevrolet Chevette, but there are many smaller cars that use the same core. Print out the picture on a color ink-jet printer and take it to the local auto parts store. They should have them. Otherwise, you can order it from Danger Den with the bards already installed for around $37.00
Hoot
res0r9lm
florida
Hoot
Hoot, why would you pick the two sunon's over two panaflo m1's
Hoot
Inactive Moderator
Twin Cities
Actually, I'm using the Panaflo equivalent. I recommended the Sunon because they have the same specs for a few dollars less. At the slow speed they run at, the bearings will probably last a long time in either case.
Hoot
overdoze
overdoze
Texas
Thanks Hoot. learning new things everyday. This forum is great. I plan on water cooling a lot of computers. this convert to lots of money safe. Thanks again you guys are cool :)
muddocktor
Retired
New Iberia, LA
I ordered 1 of those 84 cfm Sunon fans a few months ago from millisec.com and they sent me a 86 cfm Panaflo 120 instead because he had run out of the Sunon fans. That is what I'm presently using on my pelt/watercool P3 rig.
Al666
Panaflo 86CFMs are just fine...
but I am wondering how much diff. you see with the sandwich fan setup?
I see no performance change at all on my new chromie Xtreme here...
maybe that's because you guys are using heatercores and it's creating back pressure on the fan... so it performs maybe better with 2 fans on the core... i don't know... fill me in...
