flyingember,
I seriously disagree with your statement. In my case Partition Magic has been flawless *every single* time i've needed.... for the last 12 years (already used it a few tens of times already). I am not saying that you do not need backups, just in case, but seriously doubt you can say like that that it has a 30% failure rate.... In my experience, most of the times it fails it is because of users not knowing what they are doing.
Regarding your statement that 'the only reason to partition is to separate data from OS', I feel like this is also too simplistic I can think of the following reasons :
- There ARE performance AND space gains to be achieved with smaller partitions. (ever heard of cluste sizes?). I know NTFS or HPFS do not have this problem, but then you need to be using an OS that supports them.
- There is also the fact that separate partitions can and will in some cases mantain part of your data isolated from the rest of the system
- There is also the compatibility advantages if you use other OS's like linux, OS/2, win95,...
- Another reason to have smaller partitions could be the need to avoid too costly defragments or scandisks
- Also to take into consideration, and depending on your backup strategy, you may want to have small partitions easier to image.
Regards
FTC
