So for my case i bought a 120mm fan for side cooling. But i decided to go with a 200mm side cooling fan that is compatible with my case instead so i had the 120mm to play around with. The fan is an Antec 120mm Red LED Case Fan (Specs for the 120mm Antec listed below).
My question is, can i use this on my Cooling Master Hyper 212 EVO as a 2nd "push" fan. The EVO comes with adapters so that i can just slide it over the heatsink just like the fan that was included with the EVO. I plan on running it using my NZXT Sentry Mesh fan controller and leaving it set on the highest speed setting on the adjustable slider included with the Antec. Will using this Antec "Case" fan present any problems (i cant think of any, but it is listed as a "case" fan and is LED so i just want to make sure)? Thanks for any help in advance....
Antec Model
761345-75026-4
Spec Type
Case Fan
Compatibility
Case
Fan Size
120mm
RPM
1200 / 1600 / 2000 RPM
Air Flow
39 / 56 / 79 CFM
Noise Level
25 / 28 / 30 dBA
Power Connector
3 / 4 Pin
Color
Transparent LED Red
Physical Spec
Dimensions
120 x 120 x 25mm
Features
3-speed switch lets you balance quiet performance with maximum cooling
3-pin and 4-pin power connectors provide convenient connections to your motherboard or power supply
Fan-speed monitoring capability included (requires compatible motherboard)
System Specs:
-EVGA SuperClocked 012-P3-1573-KR GeForce GTX 570 HD w/Display-Port (Fermi) 1280MB 320-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
- GIGABYTE GA-Z68XP-UD3P LGA 1155 Intel Z68 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
- Western Digital Caviar Black WD1001FALS 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - OEM
- CORSAIR Professional Series HX650 (CMPSU-650HX) 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power Supply
- Crucial M4 CT064M4SSD2 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
- COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
-G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL (9-9-9-24-2N; 1.5V)
-COOLER MASTER Hyper 212 EVO RR-212E-20PK-R2 Continuous Direct Contact 120mm Sleeve CPU Cooler Compatible
-3 [200mm] fans (side, front, top) & 1 [120mm] rear fan; 2 [120mm] push/pull heatsink fans
-ASUS 24X DVD Burner - Bulk 24X OEM
-Intel i5 2500k 3.3 GHz 6MB Cache CPU
Antec Model
761345-75026-4
Spec Type
Case Fan
Compatibility
Case
Fan Size
120mm
RPM
Air Flow
39 / 56 / 79 CFM
Noise Level
25 / 28 / 30 dBA
Power Connector
3 / 4 Pin
Color
Transparent LED Red
Physical Spec
Dimensions
120 x 120 x 25mm
Features
System Specs:
