137Gig limited :(
JigPu
Inactive Pokémon Moderator
Vancouver, WA
SP1 is supposed to give support automatically. If you're not into installing it though for some reason, I've also heard the following registry mod works :)
Originally posted by redduc900 in THIS thread.
You'll need to enable "Large Drive Support" by editing the Registry. Expand the following branch...
HKEY_LOCAL_MACHINE | SYSTEM | CurrentControlSet | Services | atapi | Parameters
In the RH pane, you'll need to add a new DWORD called...
EnableBigLba...with a DWORD Value of 1
The following MSKB article describes the 137GB limitation, and how to enable 48-bit LBA in XP pre-SP1...
How to Enable 48-bit Logical Block Addressing Support for ATAPI Disk Drives in Windows XP
The above Registry edit enables support for drives larger than 137GB in W2K pre-SP3 and XP pre-SP1. It's needed anytime a HDD larger than 137GB is connected to the MB's ATA bus, regardless of any BIOS that supports 48-bit LBA. :)
JigPu
