- Jul 17, 2003
While troubleshooting what ended up being a dead 980Ti, I found my 140 mm case fan to be making noise which proved to be a worn out sleeve bearing. I'm looking for a replacement. My citerea is:
1) Silent. It has to be quiet. Maybe around 25 db (A) or less.
2) High CFM. Of all of the fans that are silent, it needs to push the most air. 50 CFM may be too high for the sound level I'm looking for but higher is better.
3) Cost. This is the lowest on my list but I don't want to spend $40 on a single fan either.
I will sacrifice CFM for noise reduction. If I can hear it from under my desk, it's too loud. So of all of the fans that are 25db or less, it has to have the highest CFM.
Looking at reviews, including one from our very own ehume
http://www.overclockers.com/15-case-fans-tested-ultimate-140-mm-roundup/
I'm looking hard at the Noctua A14 https://www.newegg.com/Product/Product.aspx?Item=N82E16835608035&ignorebbr=1
I'm also thinking about several of the Fractal Design fans like https://www.newegg.com/Product/Product.aspx?item=N82E16835352026
