- May 13, 2002
- seaside hts nj
OK here are the benchmarks you asked for!!
had to give here 2volts to run 3dmark
THIS CHIP ROCKS!!!!!!!!
hellrazrblade said:seems that your video is holding you back or something. you probably need to tweak it and make sure theres no other proggies running (use run --> msconfig). considering i get 8800 3dmarks...
how in the world is the memory bandwidth only in the 2300 range? mine gets like 2000 (using PC2100) and you're running at near PC3200 speeds.
i'm getting greedy right?Pyros said:Congrats to you on the 2Ghz on air. That is a major achievement I think. It seems to me that you have reached the biggest problem with overclocking. When is 'enough enough'? I have heard of people not being able to OC as well after unlocking a chip, and since your chip is still locked :Quote" Do you think if I unlock it I could get more????" I would try everything else I could to get a higher OC before unlocking. Better safe that sorry.Good luck.
i set to 2.5(from 2) but cant get morePyros said:Yea, I would say your getting greedy, but I would say your almost at a god-like status(or atleast demi-god) with that xp1600 OC on air, so that justifies it.I decided to get greedy about a week about too, but I ended up with a corrupt HD and had to reload windows xp.
btw, have you tried lowering you memory settings to see if it helped? It will lower your benchmarks probably, but it might let you know if the memory is the problem.
