- Jun 6, 2002
the sad thing people are buying these 2000xp chips when the 1800xp plus can easly hit the speeds that a 2000xp does. why waste the money..
196mhz OC for this xp1600 isnt impressive... i was aimming for 400mhz OC. whats holding me back is my crappy pc2100 ram. I will get some corsair PC3500 later so for now this is all i can do. unlocking the chip wont do me any good cuzz this dumb bios has no multiplyer settings. the old bios version does, and thats what im looking for. I just been lazy so i havent looked for awhile. If i can get the multiplyer settings i would bump up the multiplyer since my ram sucks to get a much better OC. this chip is at stock voltage and isnt even breaking a sweat. its like 38c idle and 44c load V7+ HSF. I gotta update my sig cuzz im using the volcano on my AMD not my intel. so when i get the new ram i should be at a much higher speed[XPerienceD] said:AZN, what kind of cooling are you using for your AMD system? I'm waiting for me new board & Volcano7+ to arrive. Then I'll do some overclocking! Your 196MHz overclock is impressive!
cmcquistion said:Every chip is different. What stepping do you have?
If you are running stock, that might be fine- but if you are ocing you could be looking at a very short proc lifetime.Mine's at ~55c full load, stable
