$199.99 BFG FX6800 OC 128MB Video Card
Beginner
BFG FX6800 OC 128MB Video Card with nVidia's GeForce 6800 Chip OverClocked for higher Performance.
BFG Technologies (Video Cards):
Outpost #: 4082672
Based on the same great architecture as the BFG GeForce™ 6800 Ultra OC™, this card delivers overclocked, out-of-the-box performance and superior image quality. All BFG graphics cards are fully supported by BFG Tech's Lifetime Warranty and 24/7 free technical support
Features:
* Superscalar GPU architecture
* NVIDIA® CineFX(TM) 3.0 engine
* On-chip video processor
* High-speed DDR memory interface
* NVIDIA® UltraShadow(TM) II technology
* 64-bit texture filtering and blending
* NVIDIA® Intellisample(TM) 3.0 technology
* NVIDIA® ForceWare(TM) Unified Driver Architecture (UDA)
* NVIDIA® nView(TM) multi-display technology
* NVIDIA® Digital Vibrance Control(TM) 3.0
* PCI Express support
* AGP 8X
* Microsoft® DirectX® 9.0 Shader Model 3.0 support
Specifications:
* GPU NVIDIA® GeForce™ 6800
* Bus Type AGP
* Memory 128MB DDR
* Core Clock 350MHz (vs. 325MHz Standard)
* Memory Clock 700MHz (effective)
* RAMDAC Dual 400MHz
* API Support Microsoft® DirectX® 9.0, OpenGL for Microsoft® Windows®
* Connectors VGA, DVI, S-Video-Out (DVI to VGA Adapter in the box)
* 438 million vertices/sec setup
* 22.4GB/second memory bandwidth
Requirements
System Requirements:
* Intel Pentium III, AMD Duron or Athlon class CPU with 128MB Ram,
* A minimum 300W system power supply
* An AGP 2.0 (or higher) compliant motherboard. Some motherboards violate the AGP specification and therefore this card may not physically fit in some systems.
* 50MB Hard Drive Space
* CD-Rom or DVD-Rom Readable Drive
* Windows 98 or Higher (ME, 2000, XP, NT 4.0)
http://shop2.outpost.com/product/4082672
$199.99
this sale is at Fry's i'm a booger at this, can someone please comment if this is worth it?
thanks guys
