1Ghz Athlon CPU (blue/purple core) & Asus A7V133 fsb limitation?
Thermodynamic
Hi there! I've used the jumpers on my new Asus A7V133 mobo to run the CPU at 10x multiplier, 133mhz fsb, 1.85 volts.
When I boot, the mobo sees the Athlon as only 1000Mhz (not 1.33Ghz)
The mobo manual, I noticed, says it supports up to 1250Mhz (12.5x100).
Is there a keen reason why the PCU is still running at 100mhz fsb?
Does any of this also rely on unlocking the multiplier - something I'd rather not do unless I need to?
Thanks!
Thermodynamic (Apr 29, 2001 06:03 p.m.):
Thanks!
if your proc isnt unlocked then i would have to say thats why you arnt getting any higher. have a pencil lying around? use it-
Do you have the FSB set at 133 and multilier at 10? That would give you your 1.33. That's if you have unlocked you cpu. You say you have a 1.1gig cpu right? If so you have to unlock it to get your desired results.
