1ghz now stuck at 1.23
kat
Senior Member
belding,MI,United States
I seem to be banging my head on the ceiling .111 FSB multiplier at 11, core volts 1.92, I have read just about every article I can find on ocing . cant come up with any solutions , tried every combo I can think of , multiplier at 10 FSB 112 113 114 windows freezes up low FSB and 11.5 multiplier, freezes up tried different core volts with all these combos no good results , running rc5 around the clock to burn in the chip, sure could use some help...
hmm, most of the kt133 boards don't really support a fsb of more than 110 or 115.... you might have hit the wall with this chip. I think I would keep burning it in and try to get the next multiplier.
good luck!
its a thunderbird
I've received some posts from a few other sites saying that some hi performance memory might do the trick
what do you think??
heres a complete components list of my system
AGI 300W power supply
kt7raid
384-133 memory
hedgehog with delta fan (lapped)
1ghz [email protected] now @1233.6bumped the FSB again 112
Geforce 2 GTS 64mb
sound blaster live
blaster modem
WD 20gig 7200 hard drive
elements 56x cdrom
mitsumi flopy
1 80mm and 2 60mm case fans
altech Lansing surround sound
acer cd writer
viewsonic17 moniter
led fan-temp moniter
black hydraulic case
HP970Cse printer
logitech cordless key board and mouse
cyber power battery back up
windows me
I think that's every thing
oh yea on order 2 muskin pc 128- 150 memory and swiftech 462a heatsink
Even if it is a T-bird it may be as high as it is going to go... 1230 MHz is DAMN high, even for a blue core (and if it is green, forget it!).
nagorak
about this blue core green core thing how green is green is it extremly green or sort of blue green im planing on upgrading to a 1.2 ghz as soon as the price falls off bougt my 1gig 1week to soon price fell 115.00 the very next week !! sucks
azzkicker did the voltage about a week ago still unstable at 11.5 multiplyer
i did do a little experement the other day got the idea from a guy an another site i live in MI last week the temp out side was -2C so i took some dryer vent hose and a 120mm fan cut a templte from card board and super cooled the inside of case to 5c and cpu temp to 13c booted up and ran at 1289 for about 4 hours wounder if a peliter would help
kat (Dec 25, 2000 09:02 p.m.):
nagorak
Well, by virtue of the fact that it is running at 1233, it is probably Blue ;-)
The Blues aren't really blue, they are more bluish green...you'd have to have a legit green to compare it to in order to tell for sure. Or maybe you can find a pic online.
kat that sounds like me
its about 20F outside
got my PC in the window pumping in cold air
chipset is 31F and 55F on the cpu right now
running a t bird 850@1045mhz
burn in helps too
