mine does 420krag said:
Dang bro...I am jealouse!!! Nice!! How far will the pc3000 go??
AZN said:im researching the wet side right now... trying to learn as much as i can and decide is $150-200 plus my time worth the 800mhz more.
AZN
3x and Samsung pc800FIZZ3 said:166Mhz FSB... very sweet. Are you using the 4x turbo settings? What kind of sticks do you have?
im currently up to 160 on my ddr sys. mem bandwidth is sweet too im just happy that i can use the 3:4 strap at 160.FIZZ3 said:
The Sig is always right I guess! =D
jdmcnudgent said:im currently up to 160 on my ddr sys. mem bandwidth is sweet too im just happy that i can use the 3:4 strap at 160.
yes, its quite impressive, mine will do that.FIZZ3 said:
I'm going to shoot for PC1200 rambus myself... aka 4x at 150Mhz FSB. I'll need a 133 Northy for that first though. =)
so now that i have been burning it in for a while, do you think that i can speed the timings back up??TASOS said:
If we are talking about Corsair PC-3000......
Then DDR 478 @2.9v is my top...2-3-3-7
jdmcnudgent said:yes, its quite impressive, mine will do that.
that sucks bro, keep up posted.pacino said:
Just got my new P4T533 + 2 x 256's PC4200 sammy's .. too bad I don't have a chip to try it out, I can tell it's different, the box is different with a sticker stating HT is enabled .. but still same board revision 1.03 .. oh well, I hope this won't crap out hehehe, I might wait for the 3giga to inject it into her
jdmcnudgent said:so now that i have been burning it in for a while, do you think that i can speed the timings back up??
currently at 428mhz.
i would have to look. but thanks for the info. i tried to set to 161fsb today, and it was a no go, may be the mem, may be the chip, dunno. my board only goes to 2.7v for the mem, and its currently at 2.66vTASOS said:
JD you need at least 2.9v to make the Corsair go higher
Your mobo doesnt give that kind of voltage...if i'm correct.
Also what's your rev? 1.1 or 2.1 ?
Different chips inside.
If you have the Winbond chips...you can definetely go higher
