2 questions temp probe and sound
kartoffel
Here's a couple questions for you guys.
1) what does the third temperature probe measure in MBM. I know 1 is cpu temp and 2 is case but what is 3? mine is normally around 5-6 more than my cpu (cpu at 38 and unknown at 44).
2) I was planning on using my old 3 pc speaker set. L,R and Sub but it only has a headphone jack. I got an adapter at Radio Shack to convert the headphone to RCA but all I got out is static. I know the sound card works. (borrowed a digital set of speakers) and I know the speakers work (tested on old puter). Is it possible to get the analog speakers to work with digital card?
Also I was worried about all the claims of flaky memory and mobos but I've been running solid all weekend with prime95 and sisoft. Although I do get some sisoft blue screens but that's before I even do any testing. weird.
Thanks,
Jeff
Thanks,
Jeff
the third temp is for the "northbridge",and are the speakers amplified?
____________________________________________________
def>
"Northbridge - This is part of a chipset in a PC that controls communications between system memory, the processor, external cache, and the AGP bus. See also southbridge. You must pair a northbridge chip with a southbridge chip to make a usable chipset. "
kartoffel said:
The speakers are amplified. They are these logitech ones http://www.logitech.com/cf/products/productoverview.cfm/3261.
I went to best buy to buy a 5.1 system. But was appalled at the prices. so I just got these.
Wow the northbridge is that hot. Is that a normal temp for it or should I try to make it lower?
Thanks,
Jeff
on the dragon+ you have a fan on it,it's ok,that temp fluctuates alot.it's ok.
