- Jul 29, 2013
Hi,
In Dell UP2715K specs they say you have to use 2 x DP 1.2! to run it native res (5120x2880) @ 60hz.
But as I understand (cos Im running this setup now: 1 DP runs 2560x1600 @ 60hz) when I use 2 1.1a cables it should be total 5120x1600 @ 60hz? If not than what refresh rate I will get running two 1.1a DP cabes at native res? will it even run?
Btw, my GPU is Quadro 6000, currently it powers Dell U3014 ([email protected]).
Its off topic, but if you have experiance please advice:
What did u pick in my situation Dell U3014 (2560x1600 30" or UP2715K (5120x2880 27")
(im doing 3D, video ect... No gaming)
And IPS glow on U3014 is huge, is it normal on IPS?
Also I got some barely visible sploches in middle gray(not IPS glow or backlight bleed, I think its light difusor).
UI size of 5K? What problem I will face with that hight PPI?
Thanx to everyone who will reply.
