. . . when you say "I literally just plopped my pc in a large tupperware container full of horse laxative", does that include any mechanical hard drives? I surely hope not, as mechanical hard drives are exposed to the air via a filter, and would soon fail once the mineral oil gets in.
I thought the case itself would make for a decent heat pipe to move the heat from the oil into the air. I was partly right. The oil is considerably cooler near the base the container and much warmer near the processor and power supply.
I'm amused that you know this, trents. Wanna talk about it?
Well, every parent of young children should know this. When the kids get constipated because they won't eat their veggies, give them some mineral oil laxative. After that, they will eat their veggies.
Good News!
Ok, So I finally got my Nvidia 970 graphics card, and I have a NH-D15 aftermarket heat sink with duel fans installed and everythings ready to go.
I'm buying a couple more gallons of horse laxative because the second tower of the heat sink is almost completely exposed to the air. I will give overclocking results shortly...
Dis I gotta see.
This gonna be good
That stuff expensive?
Put a little filter "sock" on the pump inlet, and let that do the cleaning for you. Just make sure it can't get sucked into the pump.
BTW, it's also a people laxative...
There is no inlet, it's a circulation pump.
OP- you need to set up a LARGE radiator outside the mineral oil and cool it that way. This will cost $$$. You're better off taking your parts out of this goo and running your PC normally. You're doing this very wrong.
YOU DO NOT NEED A LARGE RADIATOR! If your mineral oil pc build is built using a 5 gallon aquarium, then yes, you may want a radiator and a complicated pump system to circulate the oil.
The trick is if you have 20 gallons of mineral oil the oil will NEVER heat up enough to warrant installing a radiator. I mean I've been running this thing for well over a month now overclocked with no heat problems whatsoever. The heat dissipates into the room faster than the cpu and graphic card is adding heat to the oil.
Well that depends on how long you run your rig, really.
My rig would heat that oil up in ~2 hours I bet. 2 GPU's @ full load + CPU @ 80% load 24/7....
Or at least, a pump to circulate the oil a bit eh?
With 20 gallons of mineral oil it doesn't matter how long you run your rig. You can run prime 95 all day long and the oil won't get much hotter than room temperature. Your rig doesn't sound that much different than mine, except for the fact that you have two graphics cards instead of one.
You will not over heat the oil in your mineral oil pc if you immerse your computer in 20 gallons or more of mineral oil even if you run your pc 24/7, and I encourage anyone out there to prove me wrong.
