Hi All
Been lurking for a while, thought i should post up this new build and some piccies
My new PC. 14 hrs of building all told and a 12 hour purging air and testing WC loop. See bottom of thread for parts list
Have done some light overclocking today, but havent really tried that hard. So far, 4.7ghz on CPU @ 75deg c, 1.35v, and 1.1ghz on GPU @ 45deg. So could be interesting where it can go when i have time to really tinker with it.
1 EK Full Cover EK-FC R9-290X Backplate $39.00
1 Powercolor Radeon R9 290 OC 4GB $479.00
1 Dell U2913WM UltraSharp 29in IPS LED Monitor $499.00
1 EK Full Cover VGA Block EK-FC R9-290X Acetal Nickel $149.00
1 Corsair Obsidian 900D Super Tower Case $439.00
4 Alphacool 19/13 Compression Fitting 90 Degree G1/4 Chrome $48.00
6 Alphacool 19/13 Compression Fitting 45 Degree G1/4 Chrome $72.00
1 Corsair AX860i Platinum Power Supply $325.00
1 Corsair Gen2 Red Sleeved Modular Cable Kit $119.00
1 Corsair Red Sleeved ATX 24pin Cable for AXi Series $29.00
1 EZ Power Supply Tester with Voltage LCD Display $25.00
1 PC Assembly Screw Kit Deluxe $25.00
1 Intel Core i7 4770K $379.00
2 Seagate Barracuda 2TB ST2000DM001 $198.00
1 Corsair Dominator Platinum CMD16GX3M2A1600C9 16GB (2x8GB) DDR3 $265.00
1 ASUS Maximus VI Formula Motherboard $449.00
1 Samsung 840 EVO Series 250GB SSD $189.00
1 Masterkleer Tubing PVC UV Reactive Red 1/2ID 3/4OD 3m $19.00
1 XSPC Twin 3mm LED Kit UV $4.00
1 XSPC Twin 5mm LED Kit UV $4.00
1 Koolance QDC No-Spill Compression Female QD4-F13X19 $19.00
1 Koolance QDC No-Spill Compression Male QD4-M13X19 $18.00
1 XSPC RayStorm D5 Photon AX360 Water Cooling Kit $309.00
1 XSPC AX480 Radiator Black $125.00
1 Bitspower G1/4 Black Sparkle Triple Rotary 90 Degree CC5 $25.00
1 XSPC 24pin ATX Bridge Tool $2.00
2 Monsoon Free Center Compression Fittings, Chrome, 6 pack $78.00
2 PrimoChill Ice Intensified - UV Red $38.00
1 PrimoChill Antimicrobial Tube Coil Silver $9.00
2 Corsair Air Series SP120 Quiet Edition PWM Twin Pack $98.00
