2100+ Stepping info plz....
black_wing
Canada,Montreal
i got two processor.... AIUHB 0301 AIUHB 0305
which stepping is better?
i want to try and obtain 2.4 gigs... my 0301 max out at 2255....
is 0305 a good stepping?
flipflop
I had tested the 301 too...and I dont think this is the best one. So...I get a 307 and my OC works very well! with 1,75 volts I can reach 2,45ghz...its pretty good! :D
black_wing
black_wing
Canada,Montreal
can someone help me reach my goal??? 2.4 gigs??
i got two Proc.... and my mobo has a wire trick to unlock 12.5- mult.... should i get 12.5+ multies or not??
do you think the 0305 would perform better than 0301?
flipflop
Your mobo have the nforce2 chipset...so, probally the tbred will be unlocked by default. To reach 2,4ghz you need a good vcore something arround 1,75volts to 1,85volts, try to increase the vcore and set the multiplier to 12,5 and fsb to 192, but it deppends of your memory. I think the 305 will performe best than 301, but the best method to conclude, its testing.
