- Feb 24, 2003
- Winnipeg Canada
Well i'm in the market for a new CPU, but having a hard time deciding what to buy. I was thinking a 2700+, but everyone is saying to buy a 2100+ instead.
If I buy a 2100+ t-bred b-core (say AUIHB), will the processor be locked or unlocked? If it is locked, do I just connect the 5th bridge on the L3 to unlock? I was hoping not to have to cut any bridges or use any wire methods.
What about the 2700+? Is it locked or unlocked?
Whatever CPU i'm buying, it is going to replace the following:
900 Tbird @ 1002 (soon to be ????)
Asus A7N8X Deluxe (Uber-S 1002 Bios)
1 x 512MB Samsung PC2700 memory (2.5 cas)
SLK-800 w/ Y&S Tech 74 mm TMD fan on order (currently Alpha Pal 6035)
Thermaltake Purepower 420w PSU
Radeon 64 MB DDR (to be upgraded next)
Maxtor 7200 40 GB
Maxtor 7200 10 GB
Toshiba M1402 DVD
Lite-on 40x12x48 CDRW
NEC 19" multisync FE950
Windows XP Home
Soundstorm 5.1 sound (mobo)
Any suggestions?
Thanks,
sPaNk
Maxtor 7200 40 GB
Maxtor 7200 10 GB
Toshiba M1402 DVD
Windows XP Home
Any suggestions?
Thanks,
sPaNk
