22" Westy LCM-22w2 Owners Reviews
BoysBoysBoys
I picked one up from best buy on black friday. I hooked it up to my xbox 360 at 720p it looked very clear and crisp, the colors were good, very little bleeding across the top, the only thing that I noticed was the color banding was pretty bad. Are there any other owners that can check to see if there is color banding when you hook it up to a PC via DVI? I don't have my computer complete yet to test it. Thanks!
I picked up the 32". Vga seems fine, but I need to get my rig back together to test the DVI to hdmi. I have been having a problem with the hdmi though. The unit switches back and forth between invalid format and a terribly distorted picture when I hook it up to my cable box. YPbPr works fine though. I haven't figured out if it's the tv or the box. Any ideas?
I picked up a 22" Westy and am very pleased with it.
I am using it with a DVI cable and have no banding issues. Mine does have a scratch on it so I will be replacing it.
This is my first lcd and I am very pleased with it for watch movies.
