Hi Everyone .
i am new here
my gear is listed below ...
i am trying to get my Tbird temp lower then 55C
i found fan's that work on a 220V that i can put inside my ATX ...(very cheap)
The Fan Part is : DF2A12SM Synaeon Industrial Co. AC 220/230V 50/60Hz 0.14/0.13A
Q :- Does it helps if i make 2 holes in my case and put them inside on the door
one for get air out and one for get air in (over the CPU)
and i can take the wires outside the box to connect to power , instead of taking it from the computer powersupply ?
thank you for any help ...
i am new here
